OpenSSH future RSA host key deprecation
Please note that RouterOS supports rsa-sha2-256 for host key algorithm just fine. The recent issue is about public key authentication.
I also ran into this just today. Seems still present in ROS 7.1.
Please fix ASAP.
Here is my debug putput from OpenSSH (on an Arch Linux):
~ $ ssh -vvvv automation@192.168.0.2
OpenSSH_8.8p1, OpenSSL 1.1.1l  24 Aug 2021
debug1: Reading configuration data /home/user/.ssh/config
debug1: /home/user/.ssh/config line 1: Applying options for *
debug3: kex names ok: [diffie-hellman-group1-sha1]
debug1: Reading configuration data /etc/ssh/ssh_config
debug2: resolve_canonicalize: hostname 192.168.0.2 is address
debug3: expanded UserKnownHostsFile '~/.ssh/known_hosts' -> '/home/user/.ssh/known_hosts'
debug3: expanded UserKnownHostsFile '~/.ssh/known_hosts2' -> '/home/user/.ssh/known_hosts2'
debug3: ssh_connect_direct: entering
debug1: Connecting to 192.168.0.2 [192.168.0.2] port 22.
debug3: set_sock_tos: set socket 3 IP_TOS 0x48
debug1: Connection established.
debug1: identity file /home/user/ansible/id_rsa_automation type 0
debug1: identity file /home/user/ansible/id_rsa_automation-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.8
debug1: Remote protocol version 2.0, remote software version ROSSSH
debug1: compat_banner: no match: ROSSSH
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to 192.168.0.2:22 as 'automation'
debug3: record_hostkey: found key type RSA in file /home/user/.ssh/known_hosts:143
debug3: load_hostkeys_file: loaded 1 keys from 192.168.0.2
debug1: load_hostkeys: fopen /home/user/.ssh/known_hosts2: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts2: No such file or directory
debug3: order_hostkeyalgs: prefer hostkeyalgs: rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,rsa-sha2-512,rsa-sha2-256
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,ext-info-c
debug2: host key algorithms: rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,rsa-sha2-512,rsa-sha2-256,ssh-ed25519-cert-v01@openssh.com,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,sk-ssh-ed25519-cert-v01@openssh.com,sk-ecdsa-sha2-nistp256-cert-v01@openssh.com,ssh-ed25519,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ssh-ed25519@openssh.com,sk-ecdsa-sha2-nistp256@openssh.com
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: diffie-hellman-group-exchange-sha256
debug2: host key algorithms: ssh-rsa,rsa-sha2-256
debug2: ciphers ctos: aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,aes192-cbc,aes256-cbc,3des-cbc
debug2: ciphers stoc: aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,aes192-cbc,aes256-cbc,3des-cbc
debug2: MACs ctos: hmac-sha1,hmac-md5
debug2: MACs stoc: hmac-sha1,hmac-md5
debug2: reserved 0
debug1: kex: algorithm: diffie-hellman-group-exchange-sha256
debug1: kex: host key algorithm: rsa-sha2-256
debug1: kex: server->client cipher: aes128-ctr MAC: hmac-sha1 compression: none
debug1: kex: client->server cipher: aes128-ctr MAC: hmac-sha1 compression: none
debug3: send packet: type 34
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(2048<7680<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug3: receive packet: type 31
debug1: SSH2_MSG_KEX_DH_GEX_GROUP received
debug2: bits set: 1019/2048
debug3: send packet: type 32
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug3: receive packet: type 33
debug1: SSH2_MSG_KEX_DH_GEX_REPLY received
debug1: Server host key: ssh-rsa SHA256:XXXXXXXXX
debug1: Host '192.168.0.2' is known and matches the RSA host key.
debug1: Found key in /home/user/.ssh/known_hosts:143
debug2: bits set: 1041/2048
debug3: send packet: type 21
debug2: set_newkeys: mode 1
debug1: rekey out after 4294967296 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug1: SSH2_MSG_NEWKEYS received
debug2: set_newkeys: mode 0
debug1: rekey in after 4294967296 blocks
debug1: Will attempt key: /home/user/ansible/id_rsa_automation RSA SHA256:XXXXXXXXX explicit
debug2: pubkey_prepare: done
debug3: send packet: type 5
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering public key: /home/user/ansible/id_rsa_automation RSA SHA256:XXXXXXXXX explicit
debug1: send_pubkey_test: no mutual signature algorithm
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
automation@192.168.0.2's password:
[admin@ap] > /system/routerboard/print
       routerboard: yes
        board-name: wAP ac
             model: RouterBOARD wAP G-5HacT2HnD
     serial-number: XXXXXXX
     firmware-type: qca9550L
  factory-firmware: 3.34
  current-firmware: 7.1
  upgrade-firmware: 7.1
[admin@ap] > /system/resource/print
                   uptime: 6d6h24m15s
                  version: 7.1 (testing)
               build-time: Dec/01/2021 14:07:27
         factory-software: 6.33.5
              free-memory: 22.7MiB
             total-memory: 64.0MiB
                      cpu: MIPS 74Kc V5.0
                cpu-count: 1
            cpu-frequency: 720MHz
                 cpu-load: 0%
           free-hdd-space: 4108.0KiB
          total-hdd-space: 16.0MiB
  write-sect-since-reboot: 3962
         write-sect-total: 179388
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: wAP ac
                 platform: MikroTik
Best regards
+1
any progress?
has anyone contacted support / opened a ticket?
Following.
Ran into same issue with routerOS 7.2.1 today. Solved with .ssh/config addition as per this thread.
It’s fixed in Router OS 7.4beta2
http://forum.mikrotik.com/t/v7-4beta-testing-is-released/158543/1
What’s new in 7.4beta2 (2022-Jun-07 12:08)
*) ssh - disable ssh-rsa when strong-crypto=yes and use rsa-sha2-sha256;
