Hi, witch version of OpenSSL should I use to generate server and clients certificates to make OpenVPN work on hEX (RB750Gr3) 6.40.5?
Mikrotik does not support OpenVPN Client or Server.
best regards.
gamba47
I generated mine last year, using whatever OpenSuse 42.2 gave me at the time. I don’t think You will have much trouble with this, just use an up to date distro - or get the stable version from the project site.
That is NOT true. Here is the manual:
https://wiki.mikrotik.com/wiki/OpenVPN
Sorry
, i mean UDP support. I forget some users can connect your vpn using OpenVPN over TCP.
Yes
> interface ovpn-server print count-only
113
ROS 6.41.1
*) ovpn - fixed resource leak on systems with high CPU usage;
