Openssl CA certificate not recognized as CA
I have problem with CA certificate generated by openssl not getting recognized by RouterOS (since version 6.28 and later) as CA.
The following command is used to generate CA:
openssl req -new -newkey rsa:2048 -config openssl_mikrotik-capsman_v1.cnf -keyout ca.key -out ca.crt -nodes -x509 -days 3650
I also tried to generate CA on RouterOS and it is recognized as CA cert. If I export that certificate and import it back it is not recognized as CA :frowning:
On RouterOS version 6.27 and earlier all works OK.
Does anybody know what is wrong with my setup or is it something wrong in the RouterOS?
Here is openssl_mikrotik-capsman_v1.cnf file (without comments)
RANDFILE		= ./.rnd
[ ca ]
default_ca	= CA_default
[ CA_default ]
dir		= .
certs		= $dir
crl_dir		= $dir
database	= $dir/index.txt
new_certs_dir	= $dir
certificate	= $dir/ca.crt
serial		= $dir/serial
crl		= $dir/crl.pem
private_key	= $dir/ca.key
RANDFILE	= $dir/.rand
x509_extensions	= basic_exts
crl_extensions	= crl_ext
default_days	= 3650
default_crl_days= 30
default_md	= sha256
policy		= policy_anything
[ policy_anything ]
countryName		= optional
stateOrProvinceName	= optional
localityName		= optional
organizationName	= optional
organizationalUnitName	= optional
commonName		= supplied
name			= optional
emailAddress		= optional
[ req ]
default_bits		= 2048
default_keyfile 	= privkey.pem
default_md		= sha256
distinguished_name	= req_distinguished_name
x509_extensions		= v3_ca
[ req_distinguished_name ]
countryName                    = Country Name (2 letter code)
countryName_default            = HR
countryName_min                = 2
countryName_max                = 2
stateOrProvinceName	       = State or Province Name (full name)
stateOrProvinceName_default    = PGZ
localityName                   = Locality Name (eg, city)
localityName_default           = Kastav
0.organizationName              = Organization Name (eg, company)
0.organizationName_default      = MyCompany d.o.o.
organizationalUnitName         = Organizational Unit Name (eg, section)
organizationalUnitName_default = CAPsMAN Test
commonName                     = Common Name (eg, YOUR name)
commonName_max                 = 64
emailAddress                   = Email Address
emailAddress_max               = 40
emailAddress_default           = pki@mycompany.lan
[ basic_exts ]
basicConstraints	= CA:FALSE
subjectKeyIdentifier	= hash
authorityKeyIdentifier	= keyid,issuer:always
[ v3_ca ]
subjectKeyIdentifier=hash
authorityKeyIdentifier=keyid:always,issuer:always
basicConstraints = CA:true
keyUsage = cRLSign, keyCertSign
[ crl_ext ]
A while after the question, but it can perhaps be of help to others.
You need to set nsComment=“Generated by RouterOS” on the CA certificate to get the “A” (authority) flag when importing it.
I think I tried that too but didn’t work. I also generated CA on the Routerboard itself, exported it, deleted CA, imported previous export and still didn’t show A flag :slight_smile: Gonna have to test on newer bugfix releases and will post results.
Cheers!
Yes, that is the solution of “problem” :wink:
OK, so config file needs to be altered, only [ v3_ca ] section is relevant here …
[ v3_ca ]
nsComment = "Generated by RouterOS"
Thanx man!
Why do you need A flag? Imported certificates work fine without it.
Only difference is that imported certificates cannot be used to issue new certificates .
I meet with this same problem of flag “Authority” of imported CA certificates in ROuterOS.
So i write this post http://forum.mikrotik.com/t/correction-request-authority-flag-for-import-ca-certificate-autority-in-routeros/137960/1
To request a correction of implementation.
Not exactly.
CA certificates without ‘A’ flag cannot be used to check client certificates in open-vpn server (“require client certificate” option).
As result you must generate ALL the certificates to be used for vpn on mikrotik ONLY.
Unless something changed in latest versions, it’s not true, externally generated certificates worked fine.
thx, bro!!!
RouteOS 6.48.2 still working
