OpenVPN AES-128GCM plus TLS AUTH
Hi Members,
Hopefully someone can advise
I am trying to connect to a vpn provider which uses, username + password plus AES-128GCM plus tls-auth using a tls key
Now according to mikrotik site if you are using a GCM cipher, then the auth must be null but as GCM takes care of the auth portion too. however the SHA256 is required for the TLS-AUTH portion of the negotiation
How do I get around this. VPN provider is not accepting CBC cipher so that doesnt work
Regards,
