According to the wiki, there is currently no way to implement a full PKI with OpenVPN. Is this something that is coming, or if it has changed, can anyone provide some assistance in getting it working?
I have the following configs (SERVER):
[admin@AWAY-CLIENT] /certificate> print
Flags: K - decrypted-private-key, Q - private-key, R - rsa, D - dsa
0 D name="cert1" <MUCH DETAIL DELETED> ca=yes
1 KR name="cert2" <MUCH DETAIL DELETED> ca=yes
SERVER CONFIG:
/interface ovpn-server server
set auth=sha1,md5 certificate=cert2 cipher=blowfish128,aes128 \
default-profile=default-encryption enabled=yes keepalive-timeout=60 \
mac-address=FE:63:94:F4:15:D2 max-mtu=1500 mode=ip netmask=24 port=1194 \
require-client-certificate=no
I have created the ppp secrets as well as the client configuration. In the client, I have uploaded and imported both the CA certificate (it shows “D” flag as well) and the key and crt file (“KR” flag). Client config is:
The “cert2” certificate is the client cert/key pair with “KR” flag.
This config works, but if I ask the server to require the client certificate (which SHOULD be the CA file with “D” flag above), there is no joy, just as the wiki says.
Is this still the case, or am I doing something wrong to get this working. Is there a way to require the client to present a certificate of trust before allowing authentication to proceed?
ARGH!! I had done this, but mistyped the address for the ntp server on one router (the server). I didn’t notice that the time was off by about 18 years until I saw your post. This is now working, but there is no debug information that will confirm that it is actually using the CA certs for auth (preauth more accurately). Is there a debug topic that is available to see this? I tried ovpn,debug and ppp,debug.
1 ) username/password is always required
2 ) require-client-certificate can be enabled additionally but user/pw is still mandatory
3 ) udp is not supported
4 ) lzo is not supported
5 ) only CA cert file but not its private key should be imported to RouterOS (flag D, not KR)
6 ) only CA cert file should be set ca=yes
7 ) time synchronisation is required otherwise certs may be invalid
8 ) auth file (auth-user-pass) for client does only work if openvpn was compiled with --enable-password-save
Anyway, i suggest to answers these items clearly in the wiki. Took me a lot of time to find out about these issues.
Btw, if item 2) is true: can several clients connect with the same user/pw?
