I’m trying to limit simultaneous login with the openvpn server inside MT. I defined a profile with only-one=yes. This works with users defined localy at MT but not with users from a radius server. Any suggestions?
I think this should works because in another MT acting like hotspot the users are authenticated from a radius server and the limit to 1 is established in a profile at MT.
If you are using radius then radius server is responsible how much clients with identical usernames are allowed and setting only-one=yes on routeros will not work.
Ok, but when using radius with hotspot service is possible to control it with the profile defined at MT and using the Mikrotik-Group attribute.
I think there is a “cosmetic” error with winbox displaying active connetions with openvpn service. If there are two users with the same username initialy the time showed is same for them. Using /ppp active print the elapsep time is the correct (diferent).
