I own a Freebox (French ISP modem and a set-top box) and a brand new MikroTik HAP AC.
I read a lot of tutorial about VPN behind an ISP box but unfortunately I can’t make it works.
Do you guys could send me a link on this Forum or anywhere to help me ?
INTERNET (pub ip) – FREEBOX (192.168.1.254) – MIKROTIK (192.168.1.2) + default-pool
There is not much to it.
Firstly, import your certificate.
Secondly, you should create and configure an OVPN client interface to your server requirements.
Thirdly, you should create a new routing table and rules to route whatever you want through your VPN tunnel. Perhaps one could use IP/firewall/mangle as well.
Thank you for the answer, but it doesn’t help me. I need a tutorial because all I tried fails.
Unfortunately, I don’t have any tutorial for it. However, if you are interested, I could configure it for you via a remote desktop.
