Hello dear MikroTik Users!
I’m an IT-guy in training and I borrowed the old MikroTik my company doesn’t use anymore, so I could learn how RouterOS works in my free time.
Obviously, this is the sole reason I borrowed the MikroTik.
It’s not because I’m totally excited for having a new toy to play with.
To the problem at hand:
In my company we run OpenVPN on MikroTik, handing out an adress range which is a forbidden subset of our companys DomainController DHCP Server.
Company DHCP: 172.16.14.UU - 172.16.14.VV /24 (DC DHCP, does not hand out OpenVPN Server addresses)
OpenVPN DHCP: 172.16.14.XX - 172.16.14.YY /24 (MikroTik DHCP)
The company also does not route everything through the VPN, only 172.16.14.0/24 and some specific public IPs.
This is done via the OpenVPN configuration file we hand out.
I’ve been fiddling with OpenVPN on MikroTik at home, but I cannot get it to work like this.
You can look at my home network in the screenshot I uploaded.
What works:
- I can connect to OpenVPN
- I can ping MikroTik through VPN (+ WebFig works too)
- I get an IP adress in OpenVPN-Pool (192.168.10.90 - .99)
What does not work:
- I cannot reach anything through VPN except MikroTik
What I did (from the beginning):
- Reset company MikroTik configuration with “No default configuration” checked (I guess I did not fully grasp the consequences of doing that)
- Reinstalled RouterOS stable with netinstall
MikroTik configuration:
add name="LAN Bridge"
set [ find default-name=ether1 ] name="WAN (ether1)"
add comment="DHCP Pool for assigning on LAN network" name=lan_pool ranges=\
192.168.10.100-192.168.10.199
add comment="OpenVPN DHCP Pool" name=ovpn_pool ranges=\
192.168.10.90-192.168.10.99
add address-pool=lan_pool disabled=no interface="LAN Bridge" lease-script=\
"LAN Bridge DHCP Server" name=dhcpsrv
/ppp profile
add comment="OpenVPN Profile" dns-server=192.168.10.1 local-address=\
192.168.10.1 name=ovpn remote-address=ovpn_pool use-compression=yes \
use-encryption=yes
add bridge="LAN Bridge" interface=ether2
add bridge="LAN Bridge" interface=ether3
add bridge="LAN Bridge" interface=ether4
add bridge="LAN Bridge" interface=ether5
/interface ovpn-server server
set certificate=MikroTik.crt_0 cipher=blowfish128 default-profile=ovpn \
enabled=yes
add address=192.168.10.1/24 comment="LAN IP" interface="LAN Bridge" network=\
192.168.10.0
/ip dhcp-client
add disabled=no interface="WAN (ether1)"
/ip dhcp-server lease
add address=192.168.10.2 client-id=1:RPI3:MAC:ADD:RESS comment=\
"Raspberry Pi 3B+ static lease" mac-address=RPI3:MAC:ADD:RESS server=\
dhcpsrv
add address=192.168.10.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=192.168.10.1
add action=accept chain=input comment="Accept all from LAN" in-interface=\
"LAN Bridge"
add action=accept chain=input comment="accept OpenVPN" dst-port=1194 \
in-interface="WAN (ether1)" protocol=tcp
add action=accept chain=forward in-interface=all-ppp out-interface=\
all-ethernet
add action=drop chain=input comment="drop all from WAN" in-interface=\
"WAN (ether1)"
add action=masquerade chain=srcnat comment=\
"Change SRC IP from LAN Packets to Router Public IP (masquerade)" \
out-interface="WAN (ether1)"
/ppp secret
add name=NAME password=PASSWORD profile=ovpn service=ovpn
/system clock
set time-zone-name=TIMEZONE
OpenVPN configuration file:
client
dev tun
proto tcp
remote SOME-DDNS-ADDRESS 1194
resolv-retry infinite
nobind
user nobody
group nogroup
persist-key
persist-tun
ca SOME-EASYRSA-CERT.crt
verb 3
auth-user-pass
I tried adding
route 192.168.10.0 255.255.255.0
but that did not help.
While searching around the internet I encountered threads like these http://forum.mikrotik.com/t/no-access-to-lan-over-openvpn-can-only-ping-router/119291/1 where the solved answer is “enable the masquerade rule”.
My masquerade rule seems to be the same except for
ipsec-policy=out,none
which I tried and did not seem to help.
Do I need a different one or is mine just straight up wrong?
If you need any more information, just ask.
I hope I removed out all the sensible stuff in my configuration.
I hope someone of you can help me look in the right direction for solving this issue.
