OpenVPN certificate
Hi everybody,
I just finished my openVPN configuration on Mikrotik using GNS3 (and it’s working as charm :slight_smile: ), but one thing keep me wonder: Which certificate should I use to run OpenVPN. So far I know, that there are three ways how to generate certificate. I can either use http://cacert.org or use the easy-rsa scripts to issue these certificates and then import them to the Mikrotik (https://wiki.mikrotik.com/wiki/OpenVPN#Certificates - section 1.4 ). Or, the way that I used, I can generate these certificate directly on RouterOS (https://wiki.mikrotik.com/wiki/Manual:Create_Certificates - section 1).
My question is, which method should I use, respectively which method is the best one for somebody, who want to have remote connection to the site for his personal use?
Thank you for your help.
If just for personal use, any method will do as long as you’re comfortable with it.
