OpenVPN Client connection issues
Hey all,
Just wondering if i could get some help setting up my Mikrotik router to connect to my OpenVPN server.
The Basics;
OpenVPN box. US Based, tested working using Windows OpenVPN client, using OpenVPN 2.1.4.
Config:
local ##.##.##.##
port 1194
proto tcp
dev tun
ca ca.crt
cert server.crt
key server.key
dh dh1024.pem
server 10.8.0.0 255.255.255.240
ifconfig-pool-persist ipp.txt
keepalive 10 120
cipher none
#comp-lzo
user nobody
persist-key
persist-tun
log /var/log/openvpn.log
verb 3
Mikrotik Server info RouterOS 3.30
Config:
add add-default-route=no auth=sha1 certificate=client1 cipher=none comment="" connect-to=##.##.##.## disabled=yes mac-address=00:00:00:00:00:00 max-mtu=1500 mode=ip name=\
    ovpn-out1 password=mypass port=1194 profile=default user=MyUser
When I attempt the connection i get the following message (on the OpenVPN log), Followed directly by a disconnection as you can see below.
Thu Jan 27 12:43:08 2011 MULTI: multi_create_instance called
Thu Jan 27 12:43:08 2011 Re-using SSL/TLS context
Thu Jan 27 12:43:08 2011 Control Channel MTU parms [ L:1527 D:140 EF:40 EB:0 ET:0 EL:0 ]
Thu Jan 27 12:43:08 2011 Data Channel MTU parms [ L:1527 D:1450 EF:27 EB:4 ET:0 EL:0 AF:14/27 ]
Thu Jan 27 12:43:08 2011 Local Options hash (VER=V4): '77aaccdd'
Thu Jan 27 12:43:08 2011 Expected Remote Options hash (VER=V4): 'ddaf1b30'
Thu Jan 27 12:43:08 2011 TCP connection established with ##.##.##.##:49706
Thu Jan 27 12:43:08 2011 TCPv4_SERVER link local: [undef]
Thu Jan 27 12:43:08 2011 TCPv4_SERVER link remote: ##.##.##.##:49706
Thu Jan 27 12:43:08 2011 ##.##.##.##:49706 TLS: Initial packet from ##.##.##.##:49706, sid=817d7012 eea4a558
Thu Jan 27 12:43:17 2011 ##.##.##.##:49706 VERIFY OK: depth=1, /C=US/ST=CA/L=SanFrancisco/O=Fort-Funston/CN=Fort-Funston_CA/emailAddress=me@myhost.mydomain
Thu Jan 27 12:43:17 2011 ##.##.##.##:49706 VERIFY OK: depth=0, /C=US/ST=CA/L=SanFrancisco/O=null OU=Private/CN=myuser/name=myuser/emailAddress=myuser@domain.com
Thu Jan 27 12:43:18 2011 ##.##.##.##:49706 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Jan 27 12:43:18 2011 ##.##.##.##:49706 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Jan 27 12:43:19 2011 ##.##.##.##:49706 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Thu Jan 27 12:43:19 2011 ##.##.##.##:49706 [myuser] Peer Connection Initiated with ##.##.##.##:49706
Thu Jan 27 12:43:19 2011 myuser/##.##.##.##:49706 MULTI: Learn: 10.8.0.6 -> myuser/##.##.##.##:49706
Thu Jan 27 12:43:19 2011 myuser/##.##.##.##:49706 MULTI: primary virtual IP for myuser/##.##.##.##:49706: 10.8.0.6
Thu Jan 27 12:43:19 2011 myuser/##.##.##.##:49706 PUSH: Received control message: 'PUSH_REQUEST'
Thu Jan 27 12:43:19 2011 myuser/##.##.##.##:49706 SENT CONTROL [myuser]: 'PUSH_REPLY,route 10.8.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.8.0.6 10.8.0.5' (status=1)
Thu Jan 27 12:43:21 2011 myuser/##.##.##.##:49706 Connection reset, restarting [0]
Thu Jan 27 12:43:21 2011 myuser/##.##.##.##:49706 SIGUSR1[soft,connection-reset] received, client-instance restarting
Within WinBox i get the following errors/message from the log;
ovpn-out1: initializing...
ovpn-out1: dialing...
ovpn-out1: using encoding - SHA1
Then it disconnects and repeats the same messages.
Am i missing something obvious here? I have looked around alot, using the forums/wiki, tried alot of different things, yet i still have no luck in getting a successful connection..
Any help would be greatly appreciated!
Nobody have any helpful hints?
Or atleast links to other forum posts/articles that i may have missed? (im pretty sure i exhausted all my googling abilities prior to posting this, however i may have missed a few things). :laughing:
Sorry if i’m seeming impatient, However my vps which i run my VPN off has 3 days left before renewal, and if i can’t get this working i have no use for it at all. :slight_smile:
Still nothing?
Im sure im not the only one to experience issues with openvpn before so any help would be great.
I've same problem
Linux server
local 192.168.0.105
dev tap
port 1194
cipher none
auth SHA1
tls-server
ca /etc/openvpn/easy-rsa/2.0/keys/ca.crt
cert /etc/openvpn/easy-rsa/2.0/keys/ovpn-server.crt
key /etc/openvpn/easy-rsa/2.0/keys/ovpn-server.key # This file should be kept secret
dh /etc/openvpn/easy-rsa/2.0/keys/dh1024.pem
proto tcp-server
ifconfig 10.10.10.1 255.255.255.0
push "ifconfig 10.10.10.2 255.255.255.0"
verb 3
Mikrotik client
[admin@MikroTik] /interface ovpn-client> add connect-to=192.168.0.105 port=1194 user="username" password="password" auth=sha1 cipher=none certificate=cert2 add-default-route=no disabled=no profile=openvpn-out mode=ethernet name=ovpn-test
openvpn server log
Wed Jun 22 13:00:04 2011 TCP connection established with [AF_INET]192.168.0.102:43295
Wed Jun 22 13:00:04 2011 TCPv4_SERVER link local (bound): [AF_INET]192.168.0.105:1194
Wed Jun 22 13:00:04 2011 TCPv4_SERVER link remote: [AF_INET]192.168.0.102:43295
Wed Jun 22 13:00:04 2011 TLS: Initial packet from [AF_INET]192.168.0.102:43295, sid=077508b6 f09841bc
Wed Jun 22 13:00:05 2011 VERIFY OK: depth=1, /C=IT/ST=TN/L=Trento/O=Futur3/CN=Futur3_CA/emailAddress=d.garofalo@futur3.it
Wed Jun 22 13:00:05 2011 VERIFY OK: depth=0, /C=IT/ST=TN/L=Trento/O=Futur3/CN=client1/emailAddress=d.garofalo@futur3.it
Wed Jun 22 13:00:05 2011 WARNING: 'ifconfig' is present in local config but missing in remote config, local='ifconfig 10.10.10.0 255.255.255.0'
Wed Jun 22 13:00:05 2011 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jun 22 13:00:05 2011 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jun 22 13:00:05 2011 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Wed Jun 22 13:00:05 2011 [client1] Peer Connection Initiated with [AF_INET]192.168.0.102:43295
Wed Jun 22 13:00:05 2011 PUSH: Received control message: 'PUSH_REQUEST'
Wed Jun 22 13:00:05 2011 SENT CONTROL [client1]: 'PUSH_REPLY,ifconfig 10.10.10.2 255.255.255.0' (status=1)
Wed Jun 22 13:00:05 2011 Connection reset, restarting [0]
Wed Jun 22 13:00:05 2011 TCP/UDP: Closing socket
Wed Jun 22 13:00:05 2011 Closing TUN/TAP interface
Wed Jun 22 13:00:05 2011 /sbin/ifconfig tap0 0.0.0.0
Wed Jun 22 13:00:05 2011 SIGUSR1[soft,connection-reset] received, process restarting
Wed Jun 22 13:00:05 2011 Restart pause, 1 second(s)
after some retry i've this on log
Wed Jun 22 13:00:08 2011 TCP connection established with [AF_INET]192.168.0.102:43300
Wed Jun 22 13:00:08 2011 TCPv4_SERVER link local (bound): [AF_INET]192.168.0.105:1194
Wed Jun 22 13:00:08 2011 TCPv4_SERVER link remote: [AF_INET]192.168.0.102:43300
Wed Jun 22 13:00:08 2011 TLS: Initial packet from [AF_INET]192.168.0.102:43300, sid=5ebafb6c c973a422
Wed Jun 22 13:00:09 2011 VERIFY OK: depth=1, /C=IT/ST=TN/L=Trento/O=Futur3/CN=Futur3_CA/emailAddress=d.garofalo@futur3.it
Wed Jun 22 13:00:09 2011 VERIFY OK: depth=0, /C=IT/ST=TN/L=Trento/O=Futur3/CN=client1/emailAddress=d.garofalo@futur3.it
Wed Jun 22 13:00:09 2011 WARNING: 'ifconfig' is present in local config but missing in remote config, local='ifconfig 10.10.10.0 255.255.255.0'
Wed Jun 22 13:00:09 2011 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jun 22 13:00:09 2011 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jun 22 13:00:09 2011 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Wed Jun 22 13:00:09 2011 [client1] Peer Connection Initiated with [AF_INET]192.168.0.102:43300
Wed Jun 22 13:00:09 2011 PUSH: Received control message: 'PUSH_REQUEST'
Wed Jun 22 13:00:09 2011 SENT CONTROL [client1]: 'PUSH_REPLY,ifconfig 10.10.10.2 255.255.255.0' (status=1)
Wed Jun 22 13:00:10 2011 Initialization Sequence Completed
in mikrotik /ip firewall connection print
Flags: S - seen reply, A - assured
PROTOCOL SRC-ADDRESS DST-ADDRESS TCP-STATE TIMEOUT
0 SA tcp 192.168.88.2:37597 192.168.88.1:23 established 23h59m55s
1 SA tcp 192.168.0.102:43300 192.168.0.105:1194 established 23h59m47s
but i cant' ping mikrotik (10.10.10.2) from my openvpn server (10.10.10.1)
Please help me... help us :smiley:
news???
Try latest RouterOS version, we have fixed similar problem.
