Hi
couple of years I use this settings when I setup openvpn server on mikrotik. This configuration work with OpenVpn client version (OpenVPN 2.3.18 (old stable) – released on 2017.09.26 ) fine.
But after release new version of OpenVPN Client I cannot connect to VPN Servers. Any idea? THANK YOU!
Log from OpenVPN 2.3.18 - no problem, no issue
Mon May 28 17:03:33 2018 TLS: Initial packet from [AF_INET]####################:1194, sid=c33827a9 1af84c39
Mon May 28 17:03:34 2018 VERIFY OK: depth=0, CN=ca
Mon May 28 17:03:35 2018 Data Channel Encrypt: Cipher ‘AES-256-CBC’ initialized with 256 bit key
Mon May 28 17:03:35 2018 Data Channel Encrypt: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Mon May 28 17:03:35 2018 Data Channel Decrypt: Cipher ‘AES-256-CBC’ initialized with 256 bit key
Mon May 28 17:03:35 2018 Data Channel Decrypt: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Mon May 28 17:03:35 2018 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Log from OpenVPN 2.4.6 - UNABLE TO CONNECT
Mon May 28 16:47:41 2018 Attempting to establish TCP connection with [AF_INET]#############:1194 [nonblock]
Mon May 28 16:47:41 2018 MANAGEMENT: >STATE:1527518861,TCP_CONNECT,
Mon May 28 16:47:42 2018 TCP connection established with [AF_INET]#############:1194
Mon May 28 16:47:42 2018 TCP_CLIENT link local: (not bound)
Mon May 28 16:47:42 2018 TCP_CLIENT link remote: [AF_INET]#############:1194
Mon May 28 16:47:42 2018 MANAGEMENT: >STATE:1527518862,WAIT,
Mon May 28 16:47:42 2018 MANAGEMENT: >STATE:1527518862,AUTH,
Mon May 28 16:47:42 2018 TLS: Initial packet from [AF_INET]#############:1194, sid=2bd5d2ac b49cfdcd
Mon May 28 16:47:43 2018 VERIFY ERROR: depth=0, error=unsupported certificate purpose: CN=ca
Mon May 28 16:47:43 2018 OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
Mon May 28 16:47:43 2018 TLS_ERROR: BIO read tls_read_plaintext error
Mon May 28 16:47:43 2018 TLS Error: TLS object → incoming plaintext read error
Mon May 28 16:47:43 2018 TLS Error: TLS handshake failed
Mon May 28 16:47:43 2018 Fatal TLS error (check_tls_errors_co), restarting
Configuration
My ovpn setup:
/certificate
add name=ca-template common-name=ca key-usage=key-cert-sign,crl-sign
add name=server-template common-name=server
add name=client-template common-name=client
sign ca-template name=ca
sign server-template ca=ca name=server
sign client-template ca=ca name=client
set ca trusted=yes
set server trusted=yes
export-certificate ca
export-certificate client export-passphrase=#######
All of certificates are: 2048
Ovpn server
Auth: sha1 (other options unchecked)
Cipher: aes 256 (other options unchecked)
Mode IP
PPP Profile
Use Encryption: yes
ovpn client config
dev tun
proto tcp-client
remote ############# 1194
ca ca.crt
cert client.crt
key client.key
tls-client
port 1194
ping 15
ping-restart 45
ping-timer-rem
persist-tun
persist-key
mute-replay-warnings
verb 3
cipher AES-256-CBC
auth SHA1
pull
auth-user-pass
route 192.168.5.0 255.255.255.0
