I am trying to connect to my vpn server, which is serving as vpn service like strongvpn. The server is working fine with windows clients (few problems, but essentially working), clients can connect, get the internal ip address, server does nat to give public ip, client gets new public ip, everything is working fine.
When I try to connect to this server with this setup:
/interface ovpn-client
add add-default-route=yes auth=sha1 certificate=cert2 cipher=aes128 connect-to=x.x.x.x
disabled=no mac-address=00:FF:96:21:DF:D4 max-mtu=1500 mode=ethernet name=ovpn-out1
password=xxx port=443 profile=default-encryption user=xxx
It connects successfully, I can ping the server from the client, but not internet traffic going through meaning i cant ping external addresses through ovpn interface. No client side nat so far, first have to make router work with it.
Firewall is empty. Route is added successfully.
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 x.x.x.x.x 1
1 DS 0.0.0.0/0 10.3.1.1 1
2 ADC 10.3.1.0/24 10.3.1.242 ovpn-out1 0
3 ADC x.x.x.0/20 x.x.x.x.x ether1-gateway 0
4 ADC 192.168.88.0/24 192.168.88.1 bridge-local 0
Please advise me on this issue.
