openvpn connect issues
I’m stuck with an openvpn connection problem. It seems not to be a client issue (O tried bothopenvpn connect for android and ios and I get the same issue)
ROS version is 6.39.1
What I’ve done is using easy-rse3 to generate my ca/server/client certs. I imported the server cert and key + ca cert in ros (ca is flagged T, server cert is flagged TK, so this should be ok)
The ovpn server is configured to use the server certificate I’ve created
set auth=sha1 certificate=xxx.crt_0 cipher=aes256 default-profile=openvpn enabled=yes require-client-certificate=yes
I tried with and without require-client-certificate
In the ovpn config file I’ve used ca cert and client cert+key
config.ovpn
proto tcp-client
remote XXX.XXX.XXX.XXX 1194
dev tun
nobind
persist-key
tls-client
ping 10
verb 3
ciphet AES-256-CBC
auth SHA1
pull
auth-user-pass
route XXX.XXX.XXX.XXX 255.255.255.0
<ca>
-----BEGIN CERTIFICATE-----
<-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN ENCRYPTED PRIVATE KEY-----
-----END ENCRYPTED PRIVATE KEY-----
</key>
error
2017-05-20 12:44:57 EVENT: RESOLVE
2017-05-20 12:44:58 Contacting XXX.XXX.XXX:1194 via TCP
2017-05-20 12:44:58 EVENT: WAIT
2017-05-20 12:44:58 SetTunnelSocket returned 1
2017-05-20 12:44:58 Connecting to [XXX.XXX.XXX]:1194 (XXX.XXX.XXX) via TCPv4
2017-05-20 12:44:58 EVENT: CONNECTING
2017-05-20 12:44:58 Tunnel Options:V4,dev-type tun,link-mtu 1543,tun-mtu 1500,proto TCPv4_CLIENT,cipher BF-CBC,auth SHA1,keysize 128,key-method 2,tls-client
2017-05-20 12:44:58 Creds: Username/Password
2017-05-20 12:44:58 Peer Info:
IV_GUI_VER=net.openvpn.connect.ios 1.1.1-212
IV_VER=3.1.2
IV_PLAT=ios
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_BS64DL=1
2017-05-20 12:44:59 VERIFY FAIL CERT_NOT_TRUSTED : depth=1
cert. version    : 3
serial number    : AB:5A:BE:86:B9:C3:61:33
issuer name      : CN=Easy-RSA CA
subject name      : CN=Easy-RSA CA
issued  on        : 2017-05-19 15:01:36
expires on        : 2027-05-17 15:01:36
signed using      : RSA with SHA-256
RSA key size      : 2048 bits
basic constraints : CA=true
key usage        : Key Cert Sign, CRL Sign
2017-05-20 12:44:59 VERIFY OK: depth=0
cert. version    : 3
serial number    : 03
subject name      : CN=XXX.XXX.XXX
issued  on        : 2017-05-20 10:18:42
expires on        : 2027-05-18 10:18:42
basic constraints : CA=false
key usage        : Digital Signature, Key Encipherment
ext key usage    : TLS Web Server Authentication
2017-05-20 12:44:59 Transport Error: PolarSSL: SSL read error : X509 - Certificate verification failed, e.g. CRL, CA or signature check failed
2017-05-20 12:44:59 EVENT: CERT_VERIFY_FAIL PolarSSL: SSL read error : X509 - Certificate verification failed, e.g. CRL, CA or signature check failed [ERR]
2017-05-20 12:44:59 EVENT: DISCONNECTED
2017-05-20 12:44:59 Raw stats on disconnect:
 BYTES_IN : 2731
 BYTES_OUT : 244
 PACKETS_IN : 6
 PACKETS_OUT : 4
 SSL_ERROR : 1
 CERT_VERIFY_FAIL : 1
2017-05-20 12:44:59 Performance stats on disconnect:
 CPU usage (microseconds): 19273
 Network bytes per CPU second: 154361
 Tunnel bytes per CPU second: 0
2017-05-20 12:44:59 EVENT: DISCONNECT_PENDING
2017-05-20 12:44:59 ----- OpenVPN Stop -----
It seems to me that the CA cert is not valid for some reason, but I can’t find one. Clock is correct on both client and ROS
ROS logs
12:44:58 ovpn,info TCP connection established from 31.157.13.136
12:44:58 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=d54c9d4cfe99b7 pid=0 DATA len=0
12:44:58 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=70d5b26da2d0e286 pid=0 DATA len=0
12:44:58 ovpn,debug,packet sent P_ACK kid=0 sid=d54c9d4cfe99b7 [0 sid=70d5b26da2d0e286] DATA len=0
12:44:58 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=70d5b26da2d0e286 [0 sid=d54c9d4cfe99b7] pid=1 DATA len=0
12:44:58 ovpn,debug,packet sent P_ACK kid=0 sid=d54c9d4cfe99b7 [1 sid=70d5b26da2d0e286] DATA len=0
12:44:58 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=70d5b26da2d0e286 pid=2 DATA len=160
12:44:58 ovpn,debug,packet sent P_ACK kid=0 sid=d54c9d4cfe99b7 [2 sid=70d5b26da2d0e286] DATA len=0
12:44:59 ovpn,debug,packet sent P_CONTROL kid=0 sid=d54c9d4cfe99b7 pid=1 DATA len=1400
12:44:59 ovpn,debug,packet sent P_CONTROL kid=0 sid=d54c9d4cfe99b7 pid=2 DATA len=1211
12:44:59 ovpn,debug,packet rcvd P_ACK kid=0 sid=70d5b26da2d0e286 [1 sid=d54c9d4cfe99b7] DATA len=0
12:44:59 ovpn,debug <31.157.13.136>: disconnected <peer disconnected>
thanks for any advice !
giuliano
Hi
I had the same problem, but I found the solution (to be honest I was surprised) - OVPN server ROS can not work without authorization by login and password. You must at least use a username with an empty password, otherwise the connection will not be established.
As a result, you get a two-factor authorization - login-password + certificate.
