OpenVpn connected but no lan neither internet
I have a mikrotik with 2 vpn servers.
The pptp server vpn i can connect and with success and is working nicely (lan + internet without problems).
The openvpn server i can connect but no lan, no internet, no nothing, just an ip from the 192.168.89.x network, nothing else, no internet, no access to lan, no access to router.
What am I doing wrong?
# oct/09/2020 14:50:22 by RouterOS 6.47.4
# software id = 3WGQ-8KGC
# model = RB951Ui-2nD
# serial number = B88C0BE34E42
add admin-mac=C4:AD:34:B4:26:ED auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] country=portugal disabled=no mode=ap-bridge \
    ssid=Wifi@Company wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=felicidade \
    wpa2-pre-shared-key=felicidade
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/interface l2tp-server server
set enabled=yes ipsec-secret=vpn1 use-ipsec=yes
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether1 list=WAN
add interface=bridge list=LAN
/interface ovpn-server server
set auth=sha1 certificate=server-certificate cipher=aes256 default-profile=\
    default-encryption enabled=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.88.1/24 comment=defconf interface=ether1 network=\
    192.168.88.0
add address=192.168.88.0/24 interface=ether2 network=192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.0 comment=defconf name=router.lan
    established,related,untracked
add action=accept chain=input comment="allow openvpn" dst-port=1194 log=yes \
    protocol=tcp
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
    protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
    invalid
    disabled=yes in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="masq. vpn traffic" log=yes \
    src-address=192.168.89.0/24
/ppp secret
add name=test1 password=test1
add name=test2 password=test2
/system clock
set time-zone-name=Europe/Lisbon
/tool mac-server
/tool mac-server mac-winbox
Thanks in advance
Any one?
Its very strange why one works and other dont.
Anyone?
It doesn’t look like anything in router’s config. Check the client side. PPTP probably uses tunnel as default gateway, do you have the same for OpenVPN?
I only have problems on openvpn. Cant find out why.
pptp = all ok :slight_smile:
openvpn = no routing, no access to the router, no access to local lan nothing. I have an ip after connect but nothing else.
Hello
You have included the 192.168.89.255 in the pool, I think this is the problem
I suggest you to change it to 253 (I have problem recently adding the 254 too)
Regards,
Damián
will try that and report
thanks :slight_smile:
Fixed
I had to remove comp-lzo from client.
mikrotik does not support
#comp-lzo
Once more:
The problem was comp-lzo. Now it works.
#comp-lzo
