I have a Mikrotik routerboard in my home with several segregated VLANs (work/family/guest). Now I would like to run OpenVPN on the routerboard so I the kids can connect to our NAS while away at school and so that I can work remotely if needed. I followed the OpenVPN documentation on the wiki to set up the OpenVPN server, and installed the latest OpenVPN client on my Windows 7 laptop. I can connect from a remote location, but I get bumped off after less than a second and put into an endless cycle of reconnecting. In the RB logs there are three entries for each cycle of connect/disconnect:
#1 buffer: memory
topics: ovpn, info
message: TCP connection established from
#2 buffer: memory
topics: ovpn, debug, error, unknown, unknown, unknown, unknown, unknown, unknown, unknown, unknown, …
message: duplicate packet, dropping
#3 buffer: memory
message: L2TPDBG===>: duplicate packet, dropping
(L2TPDBG is a system logging prefix)
I am unable to open the individual error messages in my GUI; it appears they go on indefinitely and are too big for the browser to render.
Here are my settings in the RB. Does anyone have any suggestions for fixing or troubleshooting?
# aug/27/2020 11:01:07 by RouterOS 6.45.5
# software id = L773-USV1
# model = RouterBOARD 750G r2
set [ find default-name=ether1 ] name=ether1-gateway speed=100Mbps
set [ find default-name=ether2 ] arp=proxy-arp name=ether2-vlan speed=100Mbps
/interface vlan
add interface=ether2-vlan name="vlan13 Work" vlan-id=12
add interface=ether2-vlan name="vlan14 Family" vlan-id=14
add interface=ether2-vlan name="vlan15 Guest Internet only" vlan-id=15
add arp=proxy-arp interface=ether2-vlan name="vlan18 OpenVPN" vlan-id=18
add name=dhcp ranges=192.168.88.150-192.168.88.254
add name=dhcp_pool3 ranges=192.168.3.151-192.168.3.180
add name=dhcp_pool4 ranges=192.168.4.151-192.168.4.180
add name=dhcp_vpn ranges=192.168.8.90-192.168.8.254
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=\
ether2-vlan name=default
add address-pool=dhcp_pool3 authoritative=after-10sec-delay interface=\
"vlan13 Work" lease-time=6h name=dhcp3
add address-pool=dhcp_pool4 authoritative=after-2sec-delay disabled=no \
interface="vlan14 Family" lease-time=6h name=dhcp4
# Note: In the GUI, I added a DHCP server dhcp18 for VLAN18 OpenVPN with dhcp_vpn on 192.168.8.x. It is enabled, but it is grayed out in the GUI.
/ppp profile
add local-address=192.168.8.1 name=OpenVPNUser remote-address=dhcp_vpn
set *FFFFFFFE local-address=192.168.8.1 remote-address=dhcp_vpn
/interface l2tp-server server
set authentication=mschap1,mschap2 ipsec-secret=xxxxxxxx use-ipsec=yes
#Note: According to the GUI, this is disabled
add interface=ether2-vlan list=discover
add interface="vlan14 Family" list=discover
add interface="vlan13 Work" list=discover
add interface="vlan15 Guest Internet only" list=discover
add interface=ether2-vlan list=mactel
add interface=ether2-vlan list=mac-winbox
add interface=ether1-gateway list=WAN
add list=mactel
add interface="vlan18 OpenVPN" list=discover
/interface ovpn-server server
set auth=sha1 certificate=cmmoffice cipher=aes256 enabled=yes \
require-client-certificate=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption
add address=192.168.88.1/24 comment="default configuration" interface=\
ether2-vlan network=192.168.88.0
add address=192.168.3.1/24 interface="vlan13 Work" network=\
192.168.3.0
add address=192.168.4.1/24 interface="vlan14 Family" network=192.168.4.0
add address=192.168.5.1/24 interface="vlan15 Guest Internet only" network=\
192.168.5.0
/ip cloud
set ddns-enabled=yes
add address=192.168.3.0/24 dns-server=192.168.3.10,75.75.75.75,75.75.76.76 \
domain=cmmoffice.net gateway=192.168.3.1
add address=192.168.4.0/24 dns-server=192.168.4.10,75.75.75.75 domain=\
cmmoffice.net gateway=192.168.4.1 netmask=24
add address=192.168.8.0/24 dns-server=192.168.8.10 gateway=192.168.8.1
add address=192.168.88.0/24 comment="default configuration" gateway=\
192.168.88.1
"default configuration - related established input" connection-state=\
established,related
"default configuration - allow ping etc." protocol=icmp
add action=accept chain=input comment="Allow OpenVPN" dst-port=1194 log=yes \
log-prefix="OVPN " protocol=tcp
add action=drop chain=input comment="default configuration" in-interface=\
ether1-gateway
"default configuration - forward established related" connection-state=\
established,related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
connection-nat-state=!dstnat connection-state=new in-interface=\
ether1-gateway
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
/ppp secret
add local-address=192.168.8.1 name=mylaptop password=signals remote-address=\
192.168.8.63 service=ovpn
add local-address=192.168.8.1 name=SEJohnsen password=\
"xxxxxxxxxx" remote-address=192.168.8.63 service=ovpn
/system logging
add prefix="L2TPDBG===>" topics=l2tp
add prefix="IPSECDBG===>" topics=ipsec
My config file for the Windows OpenVPN client:
#Template client.ovpnclient
client
dev tun
proto tcp-client
remote <my fqnd>
port 1194
nobind
persist-key
persist-tun
tls-client
remote-cert-tls server
ca cmmca2.crt
cert mylaptopovpn.crt
key mylaptopovpn.key
verb 4
mute 10
cipher AES-256-GCM
auth SHA1
auth-user-pass pppsecret.txt
auth-nocache
