Hello!
We use RB850Gx2, it’s powerpc based cpu. While using ROS v6.4x we’ve had no problems with OpenVPN service. We were using AES-265-CBC with SHA1 auth. About 2 weeks ago I updated software to ROS 7.13.1. Now I use AES-256-GCM cipher, and get these errors in Windows OpenVPN Community:
Sat Jan 27 16:21:04 2024 OpenVPN 2.6.7 [git:v2.6.7/53c9033317b3b8fd] Windows [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] [DCO] built on Nov 8 2023
Sat Jan 27 16:21:04 2024 Windows version 10.0 (Windows 10 or greater), amd64 executable
Sat Jan 27 16:21:04 2024 library versions: OpenSSL 3.1.4 24 Oct 2023, LZO 2.10
Sat Jan 27 16:21:04 2024 DCO version: 1.0.0
Sat Jan 27 16:21:06 2024 TCP/UDP: Preserving recently used remote address: [AF_INET]x.x.x.x:1194
Sat Jan 27 16:21:06 2024 ovpn-dco device [OpenVPN Data Channel Offload] opened
Sat Jan 27 16:21:27 2024 dco connect error: Przekroczono limit czasu semafora. (errno=121)
Sat Jan 27 16:21:27 2024 SIGUSR1[soft,dco-connect-error] received, process restarting
Sat Jan 27 16:21:28 2024 TCP/UDP: Preserving recently used remote address: [AF_INET]x.x.x.x:1194
Sat Jan 27 16:21:28 2024 ovpn-dco device [OpenVPN Data Channel Offload] opened
Sat Jan 27 16:21:49 2024 dco connect error: Przekroczono limit czasu semafora. (errno=121)
Sat Jan 27 16:21:49 2024 SIGUSR1[soft,dco-connect-error] received, process restarting
Sat Jan 27 16:21:50 2024 TCP/UDP: Preserving recently used remote address: [AF_INET]x.x.x.x:1194
Sat Jan 27 16:21:50 2024 ovpn-dco device [OpenVPN Data Channel Offload] opened
Sat Jan 27 16:22:11 2024 dco connect error: Przekroczono limit czasu semafora. (errno=121)
Sat Jan 27 16:22:11 2024 SIGUSR1[soft,dco-connect-error] received, process restarting
Sat Jan 27 16:22:12 2024 TCP/UDP: Preserving recently used remote address: [AF_INET]x.x.x.x:1194
Sat Jan 27 16:22:12 2024 ovpn-dco device [OpenVPN Data Channel Offload] opened
Sat Jan 27 16:22:33 2024 dco connect error: Przekroczono limit czasu semafora. (errno=121)
Sat Jan 27 16:22:33 2024 SIGUSR1[soft,dco-connect-error] received, process restarting
It takes about few minutes to connect, just keeps retrying. When it is already connected, connection is stable. We have no clue, if this is a bug only when using powerpc cpu? There are no such problems on the other arm or mipsbe routers, where connection is very fast and stable.
Greets,
Marecky.
