OpenVPN disconnects every single hour
I’ve originally set up OpenVPN on v5.2 (PC/x86), all worked great except it kept killing the server as well as all active connections every 60min, sharp. Found on line it was a bug and I needed to upgrade to get it going. So now I’m on v5.14 but it looks like nothing’s changed. Anybody having similar issues? Any suggestions?
Thanks.
Anybody, anything in this matter?
All I can tell you is that OpenVPN started working around version 5.3 or 5.4 . There is no working OpenVPN in any of the previous versions. You could connect for a while and then had to restart either the OpenVPN service or the router to get it to work again. However since about 5.4 I have had no problems. I don’t use it much, but when I do, it works .. .even for 2 to 3 days at a time with a single connection.
GL
Glucz, but I’m on 5.14 now and it’s still happening. So how come it’s been fixed since 5.3 or 5.4?
