OpenVPN don't connect client
Hello!
I have same problems. I can not connect to the OpenVPN server, which raised to Mikrotik RB750.
My configuration consists of:
dev tap
proto tcp
remote 192.168.88.1
port 443
client
ca ca.crt
cert client1.crt
key client1.key
ns-cert-type server
persist-key
persist-tun
verb 1
After connecting, I see in the log Mikrotik
19:47:58 ovpn,info TCP connection established from 192.168.88.251
19:47:58 ovpn,info <ovpn-0>: dialing...
19:48:01 ovpn,info <ovpn-0>: using encoding - BF-128-CBC/SHA1
19:48:06 ovpn,info <ovpn-0>: terminating... - peer disconnected
19:48:06 ovpn,info <ovpn-0>: disconnected
19:48:29 ovpn,info TCP connection established from 192.168.88.251
19:48:29 ovpn,info <ovpn-0>: dialing...
19:48:32 ovpn,info <ovpn-0>: using encoding - BF-128-CBC/SHA1
More information can be found here:
for_OpenVPN.zip (16.7 KB)
I have a similar problem. You show how to generate certificates?
A good article on setting up OpenVPN here - http://wiki.mikrotik.com/wiki/OpenVPN
I used the second part: Creating Certificates with Easy-RSA
I was told that could build a working configuration OpenVPN to version 5.20. I have set the router to 5.11.
Edit the file /etc/vars. I like it just changed the variables:
export KEY_COUNTRY="RU"
export KEY_PROVINCE="RUS"
export KEY_CITY="Vologda"
export KEY_ORG="MIAC"
export KEY_EMAIL="mnk@myhost.mydomain"
You can use your own.
#. vars
That point gap vars
Cleaning and initialize the folder keys.
#./clean-all
Creating a master Certificate Authority (CA) certificate & key. Executed 1 time.
Certificate and key generation - ca.crt, ca.key.
#. vars
#./build-ca
Generating key and certificate for the server
Executed 1 time
#. vars
#. / build-key-server ServerName
ServerName - server name. To some additional questions can be answered 2 times “empty” on the last 2 - “y”:
Sign the certificate? [y / n]: y
1 out of 1 certificate requests certified, commit? [y / n] y
This will create a key ServerName.key, certificate ServerName.crt, request Certificate Signing Request (CSR) ServerName.csr,? Weird file? 01.pem (copy ServerName.csr)
To create a certificate for the client:
# ./build-key client0
How do you import certyfikat to Mikrotik?
Hello webroot.
I did. It connects me with openvpn.
You do that:
vi vars
source vars
./clean-all
Create CA
./pkitool --initca
Create Server Certificate
./pkitool --pass --server RB450
Convert Server private key to .pem format
openssl rsa -in keys/RB450.key -out keys/RB450.pem
Very important!
You need to edit the file keys / index.txt.attr and change “unique_subject” to “no”
Create Client Certificate
./pkitool --pass client1
Convert Client private key to .pem format
openssl rsa -in keys/client1.key -out keys/client1.pem
Referring to easy-rsa example above upload following files via sftp to RouterBoard
RB450.crt
RB450.pem
ca.crt
Import certificate on Mikrotik
/certificate
import file=RB450.crt
import file=RB450.pem
import file=ca.crt
My configuration on windows 7
dev tap
proto tcp-client
remote 192.168.178.11 1194
ca ca.crt
cert client1.crt
key client1.key
ns-cert-type server
tls-client
port 1194
persist-tun
persist-key
verb 3
auth SHA1
pull
auth-user-pass userpass.txt
Settings on mikrotik:
ppp/OVPN Server
Mode: ethernet
Default profile: cert1
ppp/Secrets
add user and settings:
local address: 10.8.8.1
remote address: 10.8.8.3
How would you have a problem, write.
Good luck.
