OpenVPN in mikrotik 6.10 with build certificates with easy-rsa 2.0 on ubuntu 12.04.4
install ubuntu 12.04.04 64bit in VirtualBox and start terminal
make password for root and login as root
sudo passwd root
sudo su -
install openvpn
apt-get install openvpn -
backup easy-rsa for router1 (my ubuntu user = libor)
cp -r /usr/share/doc/openvpn/examples/easy-rsa/2.0 /home/libor/openvpn/router1
cd /home/libor/openvpn/router1 -
install nano and edit vars
apt-get install nano
nano ./vars
– find and repair EASY_RSA= to
EASY_RSA=”/home/libor/openvpn/router1”
– change safety keys 4096bit
export KEY_SIZE=4096
– change information in certificates
export KEY_COUNTRY=”CZ”
export KEY_PROVINCE=”Czech Republic”
export KEY_CITY=”Prague”
export KEY_ORG=”company.cz”
export KEY_EMAIL=”info@company.cz”
#export KEY_EMAIL=mail@host.domain (not use)
#export KEY_CN=changeme (will be set when creating the certificate)
export KEY_NAME=”company.cz”
export KEY_OU=”company.cz”
– save and close ./vars
change link for openssl.cnf
ln -s openssl-1.0.0.cnf openssl.cnf -
set vars (alternative source ./vars)
. ./vars -
clean keys directory if exist
./clean-all -
build CA press enter for data from vars
set Common Name for example vpn-ca
Sign the certificate? [y/n] press y
1 out of 1 certificate requests - certified, comit? [y/n] pres y.
./build-ca -
build certificate for server press enter for data from vars
Common Name full domain name router1.mydomain.cz
./build-key-server router1 -
build certificate for client1 press enter for data from vars
Common Name we can press enter if name [client1] we want
./build-key client1 -
build Diffie-Hellmanovy parametr
./build-dh -
build TLS-AUTH
cd keys
openvpn --genkey -secret ta.key
Than set openvpn client with client1.crt, client1.key and ca.crt (i can put here config client openvpn)
Than copy and import certificate for server router1.crt and key router1.key to mikrotik v6.10 and all work!
My question is why? Why work client certificate if I do NOT set date/time in routerboard v6.10 (clients certificate are out of date) and in version 5 it not work!
Next question why mikrotik v6.10 routerboard OpenVPN server work without ca.crt?
I think that your OpenVPN server in version 6.10 is not secure because it does not validate client certificates!
Now I have to downgrade my mikrotik RB951Ui-2HnD to version 5 and I don’t known if this RB can be on v5.
