OpenVPN Issue Iphone
I have a issue while I want to connect with my iphone/ipad to the OpenVPN server of the mikrotik.
After a long search with certificate, I can generate and I can connect with Windows OpenVPN client to my mikrotik server.
When I try with my iphone/ipad to my microtik openvpn server, I get always the following issue.
While he pulling the settings from the server, it go wrong,
I always get the message:
TUN_SETUP_FAILED option_error : only topology ‘subnet’ and ‘net30’ supoorted [ERR].
In also try into my OpenVPN server to setup the SUBNET to /30, but still the same issue, the windows client work perfect.
The Mikrotik OpenVPN server give always topology [p2p] instead off subnet or NET30.
Please I look many hours to solved it, but I can`t find it.
Thanks for supporting me,
Sven
Why do you not use the l2tp protocol, it does not require any software on the client side and is well documented.
Hi Hello,
L2TP/IPSec is not a possible way to make a VPN connection, because my L2TP server don`t work after NAT.
My Internet provider give my a External Fix IP that have a router to a FIX intranet address.
All the ports will be forwarded to that internal IP address, this IP address is my WAN side of my mikrotik.
When I try this with my Iphone/Ipad device in my internal network it work perfect, but not outside.
And of course I open alle the ports in the firewall settings of my Mikrotik (1701,500,4500 UDP)
I used the last software RouterOs version.
The L2TP server dont work very well, and dont give IP address that I setup into the L2TP server, only internal it work.
Also I read that L2TP/IpSec server only will work for 1 connection, not for more then 1 !
Sven
