I feel like i have been through every tutorial and forum post out there on fixing this issue. Just like countless other posts, I am not able to ping a computer on our office lan subnet from a computer on our remote subnet over an openvpn connection. I can ping the gateways from either side, but the packets will just not go through. Hopefully one of you kind souls can spot an issue in our configuration.
Server Side
aug/27/2018 16:26:29 by RouterOS 6.42.7
software id = 6A1G-CH30
model = RouterBOARD wAP R-2nD
serial number = 870E0760D839
/interface lte
set [ find ] mac-address=B6:9E:9D:2E:30:96 name=lte1
add admin-mac=64:D1:54:7D:CE:72 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country="united states" disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=DCMRouter wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=wap.tracfone
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.1.120-192.168.1.130
add name=pool-ovpn ranges=10.255.255.2-10.255.255.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add local-address=10.255.255.1 name=profile1 remote-address=pool-ovpn
/routing ospf area
add area-id=0.0.0.255 name=area255
add comment=defconf interface=lte1 list=WAN
/interface ovpn-server server
set certificate=SERVER default-profile=profile1 enabled=yes netmask=32
add address=192.168.1.111/24 comment=defconf interface=ether1 network=192.168.1.0
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.111 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.111 name=router.lan
add action=accept chain=input dst-port=1194 protocol=tcp
add action=accept chain=input protocol=ospf
add action=accept chain=forward src-address=10.255.255.254
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ppp secret
add name=DCRRouter1 profile=profile1
/routing ospf network
add area=area255 network=10.255.255.0/24
add area=area255 network=192.168.1.0/24
/system clock
set time-zone-autodetect=no time-zone-name=America/Kentucky/Louisville
/system logging
add topics=debug
/system ntp client
set enabled=yes server-dns-names=0.pool.ntp.org,1.pool.ntp.org,2.pool.ntp.org,3.pool.ntp.org
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
Server Routes
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 lte1 2
1 ADC 10.255.255.254/32 10.255.255.1 0
2 ADC 100.84.9.172/32 100.84.9.172 lte1 0
3 ADC 192.168.1.0/24 192.168.1.111 bridge 0
4 ADo 192.168.88.0/24 10.255.255.254 110
Client Config
aug/27/2018 16:36:28 by RouterOS 6.42.7
software id = GXG5-3WJ6
serial number = 7B7307D42EF2
/interface lte
set [ find ] mac-address=46:7F:C0:A2:6C:B6 name=lte1
/interface ovpn-client
add connect-to=notreallyourname.ddns.net mac-address=02:3D:FD:9E:80:DD name=ovpn-DCMain user=DCRRouter1
add admin-mac=64:D1:54:7D:C7:66 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country="united states" disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=DCRRouter1 wireless-protocol=802.11
/interface lte apn
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
/routing ospf area
add address=192.168.88.1/24 comment=defconf interface=ether1 network=192.168.88.0
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=forward src-address=10.255.255.0/24
add distance=1 gateway=lte1
add area=area255 network=192.168.88.0/24
/system clock
/system logging
add topics=debug,!ospf
/system ntp client
set silent-boot=no
/tool mac-server
Client Routes
0 A S 0.0.0.0/0 lte1 1
1 ADC 10.255.255.1/32 10.255.255.254 ovpn-DCMain 0
2 ADC 33.208.199.255/32 33.208.199.255 lte1 0
3 ADo 192.168.1.0/24 10.255.255.1 110
4 ADC 192.168.88.0/24 192.168.88.1 bridge 0
Any ideas?
