OPENVPN ppp and no access to LAN
Hello to forum
I have an installation where I am setting up an openvpn which works but I have access only to teh route as VPN server and to teh router through winbox.
I have research extensively the forum for answers but nothing really works.
I have tried to make my LAB bridge proxy-arp and use the accept rule of input for my in-interfaces= pppall but no succes also.
Disable all my firewall rules to check if there is a problem but no success a also
Note that I have used as part of my VPN pool a part of my actually subnet a /29, but no success also.
I suppose should not be an issue but teh common resolution do not work.
I was wondering if a solution might be given through teh forum and if yes what parts of my code should be necessary to be sent over for check.
Thanks for your attention
openvpn is very wealthy in it’s feature-set … please give us an "/export/withou… " from your terminal as an attachment to your next post, for further investigations.
nice gesture would be, to make a little sketch with relevant links and addresses … to fetch the issue even faster …
