OpenVPN problem with certificate
Hi i have setting up a mikrotik as a server openvpn and the other as a client.
it’s work perfuctually without require certificate of user’s but when i check “require certificat of client”
it doesn’t work -_-
when i check the difference between what i have and what the tutoriel have there is the only diffrence
mine:
the tuto:
thanks
Second picture is from Old RouterOS. Flags in your first picture are correct, K- private key and T trusted.
Thanks for reply
but i get the openvpn works without Certificat and when i require the client certificate it not working :frowning: where can be the problem
From the tuto, you have choose the wrong certificate in openvpn server, instead you would choose the CaCert.
This may be the problem.
Br.
