How i can enable/view ovpn log in MikroTik to view why i can’t connect
Client log show only this
Sat Apr 14 14:20:48 2012 OpenVPN 2.0.9 Win32-MinGW [SSL] [LZO] built on Oct 1 2006
Sat Apr 14 14:20:52 2012 IMPORTANT: OpenVPN's default port number is now 1194, based on an official port number assignment by IANA. OpenVPN 2.0-beta16 and earlier used 5000 as the default port.
Sat Apr 14 14:20:52 2012 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sat Apr 14 14:20:52 2012 Control Channel MTU parms [ L:1575 D:140 EF:40 EB:0 ET:0 EL:0 ]
Sat Apr 14 14:20:52 2012 Data Channel MTU parms [ L:1575 D:1450 EF:43 EB:4 ET:32 EL:0 ]
Sat Apr 14 14:20:52 2012 Local Options hash (VER=V4): '10f35004'
Sat Apr 14 14:20:52 2012 Expected Remote Options hash (VER=V4): 'a917298a'
Sat Apr 14 14:20:52 2012 Attempting to establish TCP connection with 46.253.XX.XXX:1194
Sat Apr 14 14:20:52 2012 TCP connection established with 46.253.XX.XXX:1194
Sat Apr 14 14:20:52 2012 TCPv4_CLIENT link local: [undef]
Sat Apr 14 14:20:52 2012 TCPv4_CLIENT link remote: 46.253.XX.XXX:1194
Sat Apr 14 14:20:52 2012 Connection reset, restarting [-1]
Sat Apr 14 14:20:52 2012 TCP/UDP: Closing socket
Sat Apr 14 14:20:52 2012 SIGUSR1[soft,connection-reset] received, process restarting
Sat Apr 14 14:20:52 2012 Restart pause, 5 second(s)
MikroTik log shows only
14:14:20 ovpn,info TCP connection established from 46.253.XX.XXX
14:14:25 ovpn,info TCP connection established from 46.253.XX.XXX
