OpenVPN problems
I have the following problems using 5.13 x86 (5.14 had more openvpn bugs as i read and i dare not test 5.15 yet), using freeradius as authentication backend.
  • some connected users have the router’s uptime in their connection uptime (even when actually they have just connected)
  • some users get stuck, that is the router thinks they are still connected and by doing so it didnt log out in the radius (default keepalive timeout, 60) - this is a problem since i limit simultanious login to 1 for each
  • today i had to restart the whole router AND radius because as i tried to remove one of those stucked users all of them disconnected, but only from the router they werent removed from ip pool and neither from radius
  • and most serious: if i try to connect without user/pass (i know it is not a feature of mikrotik, but still if i try to do) the same happens as above, that is all users disconnect
Please advise me on the issues above and/or fix them.
OpenVPN on the mikrotik has always been bad. The best thing you can do is keep sending these problems directly to support@mikrotik.com
