And small update:
- Ping 10.2.0.1 from Mikrotik does not work. 2. I connected my second iPhone to Synology VPN and received 10.2.0.3. I can ping form 10.2.0.2 to 10.2.0.3 and it works.
This means that the problem is on Mikroitk.
And erratum : Ideally, I’d like to be able to access my MikroTik’s webfig interface by entering 10.2.0.2 on my iPhone while it’s connected to my Synology [should be 10.2.0.0].
My aim: I want to not to pay for Public IP anymore and to be able to use the VPN connected to my home network and to enter 10.2.0.2 to be able to see Mikrotik’s Config interface, and also to be able to use Winbox to connect to 10.20.0.2
Resume by AI:
ChatGPT
Analyzing the provided MikroTik configuration, here are the key points and observations:
General Configuration:
Router Model: RB951G-2HnD.
RouterOS Version: 7.12.1.
Interfaces: Standard setup with wireless (wlan1) and several Ethernet interfaces.
VPN Configuration:
OpenVPN Client: Configured to connect to MYNAME.mywire.org on UDP port 1195 with sha512 authentication and aes256-cbc cipher.
L2TP/IPsec Client: Also set up to connect to MYNAME.mywire.org.
OpenVPN Server: Enabled with various ciphers and SHA1/MD5 authentication.
IP Addressing and DHCP:
IP Pools: Two pools defined, default-dhcp for the local network and OVPN-pool for VPN clients.
DHCP Server: Configured for the local network with the pool default-dhcp.
Firewall and NAT:
Various firewall filter and NAT rules are in place.
Notable rules include allowing VPN traffic to the LAN and the router, accepting WinBox traffic (port 8291), and a masquerade rule for outbound traffic.
Specific rule to allow OpenVPN traffic (Ovpn pass) on TCP port 1194 from interface ppp-out1.
Wireless Configuration:
Wireless network configured with WPA2-PSK security.
Miscellaneous:
DNS: Remote DNS requests are allowed.
IPsec Peer: Configured with a peer entry pointing to MYNAME.mywire.org.
System Clock: Set to the Warsaw timezone.
Security Observations:
Default firewall rules are in place to protect the router, including dropping invalid connections and restricting input chain to non-LAN interfaces.
The use of both SHA1 and MD5 in the OpenVPN server settings is noted; however, these are generally considered less secure than newer algorithms.
Potential Areas for Review:
Ensure the OpenVPN and L2TP/IPsec client configurations match the server settings at MYNAME.mywire.org.
Review the OpenVPN server settings, particularly the cipher and authentication methods, for security and compatibility with clients.
Verify the NAT and firewall rules, especially if there are specific traffic flow requirements or issues.
This configuration appears to be set up for both connecting to a remote VPN server and hosting an OpenVPN server, with standard network settings for local and VPN client IP address distribution
# 2024-01-01 04:47:37 by RouterOS 7.12.1
# software id = 7KQR-3SQ7
# model = RB951G-2HnD
# serial number = XXXXXX
add name=OVPN-bridge
add admin-mac=XX-XX:6B:58:59:7F auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=MikroTi wireless-protocol=802.11
/interface ovpn-client
add add-default-route=yes auth=sha512 cipher=aes256-cbc connect-to=\
MYNAME.mywire.org disabled=yes mac-address=XX:XX:95:22:77:2C name=\
ovpn-out1 port=1195 protocol=udp user=ak4
/interface l2tp-client
add connect-to=MYNAME.mywire.org disabled=no name=l2tp-out1 use-ipsec=yes \
user=ak4
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik
/iot lora servers
add address=eu.mikrotik.thethings.industries name=TTN-EU protocol=UDP
add address=us.mikrotik.thethings.industries name=TTN-US protocol=UDP
add address=eu1.cloud.thethings.industries name="TTS Cloud (eu1)" protocol=\
UDP
add address=nam1.cloud.thethings.industries name="TTS Cloud (nam1)" protocol=\
UDP
add address=au1.cloud.thethings.industries name="TTS Cloud (au1)" protocol=\
UDP
add address=eu1.cloud.thethings.network name="TTN V3 (eu1)" protocol=UDP
add address=nam1.cloud.thethings.network name="TTN V3 (nam1)" protocol=UDP
add address=au1.cloud.thethings.network name="TTN V3 (au1)" protocol=UDP
/ip ipsec peer
add address=MYNAME.mywire.org name=peer1
add name=OVPN-pool ranges=192.168.34.100-192.168.34.150
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/interface ppp-client
add allow=pap,chap,mschap1 apn=vpn dial-on-demand=no disabled=no \
info-channel=1 name=ppp-out1 port=usb1 user=vpn
/ppp profile
set *FFFFFFFE bridge=OVPN-bridge dns-server=9.9.9.9,149.112.112.112 \
local-address=192.168.34.1 remote-address=OVPN-pool
/interface ovpn-server server
set auth=sha1,md5 certificate=SERVER cipher=\
blowfish128,aes128-cbc,aes192-cbc,aes256-cbc default-profile=\
default-encryption enabled=yes require-client-certificate=yes
192.168.88.0
add address=192.168.34.1/24 interface=OVPN-bridge network=192.168.34.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=forward comment="Allow VPN to lan" src-address=\
10.2.0.0/24
add action=accept chain=input comment="do winboxa" dst-port=8291 protocol=tcp
add action=accept chain=input dst-port=80 log=yes protocol=tcp
add action=accept chain=input comment="Allow VPN to router" src-address=\
10.2.0.0/24
add action=accept chain=input comment="Ovpn pass" dst-port=1194 in-interface=\
ppp-out1 protocol=tcp
established,related,untracked
invalid disabled=yes
in-interface-list=!LAN log-prefix=dropnotfromlan
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid disabled=yes
add action=log chain=input dst-port=80 log=yes log-prefix="input: " protocol=\
tcp
# lte1 not ready
add action=masquerade chain=srcnat out-interface=*7
add action=masquerade chain=srcnat out-interface=ppp-out1
/ip ipsec identity
add peer=peer1
/ip service
set www address=0.0.0.0/0
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add name=ak profile=default-encryption remote-address=192.168.34.154 service=\
ovpn
/system clock
set time-zone-name=Europe/Warsaw
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
