I am using Hap AX2, with latest OS version and I am unable to figure it out how to configure Openvpn clients and Wireguard clients to see each other.
192.168.200.0/25 - LAN subnet - Router IP is 192.168.200.1/25
10.168.200.0/25 - Wireguard subnet - Router IP is 10.168.200.1/32
10.168.200.128/25 - OpenVPN subnet - Router IP is 10.168.200.254/25
10.167.200.0/24 - OpenVPN site to site subnet for remote branches.
192.168.200.128/25 - OpenVPN site to site subnet for remote branch.
All interfaces belong to LAN interace list, so no additional firewall forward rules are necessary (although I tried adding those rules, but it’s the same)
When I connect to Wireguard server, I can only ping LAN subnet (and vice versa) and other Wireguard peers, but neither OpenVPN subnet or OpenVPN s2s subnet.
When I connect to OpenVPN server, I can ping LAN subnet and other OpenVPN clients and remote branches, but I can’t ping Wireguard clients.
Something I am obviously missing about routing… ![]()
Windows OpenVPN client's route table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.0.129 192.168.0.150 25
0.0.0.0 0.0.0.0 10.168.200.254 10.168.200.248 537
10.167.200.0 255.255.255.0 10.168.200.254 10.168.200.248 537
10.168.200.0 255.255.255.0 10.168.200.254 10.168.200.248 537
10.168.200.128 255.255.255.128 On-link 10.168.200.248 281
10.168.200.248 255.255.255.255 On-link 10.168.200.248 281
10.168.200.255 255.255.255.255 On-link 10.168.200.248 281
127.0.0.0 255.0.0.0 On-link 127.0.0.1 331
127.0.0.1 255.255.255.255 On-link 127.0.0.1 331
127.255.255.255 255.255.255.255 On-link 127.0.0.1 331
192.168.0.128 255.255.255.128 On-link 192.168.0.150 281
192.168.0.150 255.255.255.255 On-link 192.168.0.150 281
192.168.0.255 255.255.255.255 On-link 192.168.0.150 281
192.168.200.0 255.255.255.0 10.168.200.254 10.168.200.248 537
224.0.0.0 240.0.0.0 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 10.168.200.248 281
224.0.0.0 240.0.0.0 On-link 192.168.0.150 281
255.255.255.255 255.255.255.255 On-link 127.0.0.1 331
255.255.255.255 255.255.255.255 On-link 10.168.200.248 281
255.255.255.255 255.255.255.255 On-link 192.168.0.150 281
Windows Wireguard client's route table
0.0.0.0 0.0.0.0 192.168.255.254 192.168.255.1 2
10.167.200.0 255.255.255.0 On-link 10.168.200.2 5
10.167.200.255 255.255.255.255 On-link 10.168.200.2 261
10.168.200.0 255.255.255.0 On-link 10.168.200.2 5
10.168.200.2 255.255.255.255 On-link 10.168.200.2 261
10.168.200.255 255.255.255.255 On-link 10.168.200.2 261
192.168.200.0 255.255.255.0 On-link 10.168.200.2 5
192.168.200.255 255.255.255.255 On-link 10.168.200.2 261
192.168.255.0 255.255.255.0 On-link 192.168.255.1 257
192.168.255.1 255.255.255.255 On-link 192.168.255.1 257
192.168.255.255 255.255.255.255 On-link 192.168.255.1 257
224.0.0.0 240.0.0.0 On-link 192.168.255.1 257
255.255.255.255 255.255.255.255 On-link 192.168.255.1 257
Mikrotik routes
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, s - STATIC, d - DHCP
Columns: DST-ADDRESS, GATEWAY, DISTANCE
# DST-ADDRESS GATEWAY DISTANCE
DAd 0.0.0.0/0 10.168.1.1 1
0 As 10.167.200.32/27 <ovpn-pr2-kapija.domain.loc> 1
1 As 10.167.200.64/27 <ovpn-magacin-kapija.domain.loc> 1
2 As 10.167.200.128/27 <ovpn-pr5-kapija.domain.loc> 1
3 As 10.167.200.160/27 <ovpn-pr6-kapija.domain.loc> 1
DAc 10.168.1.0/24 ether1 0
4 As 10.168.200.0/25 WG 1
DAc 10.168.200.1/32 WG 0
DAc 10.168.200.248/32 <ovpn-w.domain.loc> 0
DAc 10.168.200.249/32 <ovpn-pr6-kapija.domain.loc> 0
DAc 10.168.200.250/32 <ovpn-pr1pr4-kapija.domain.loc> 0
DAc 10.168.200.251/32 <ovpn-pr2-kapija.domain.loc> 0
DAc 10.168.200.252/32 <ovpn-pr5-kapija.domain.loc> 0
DAc 10.168.200.253/32 <ovpn-magacin-kapija.domain.loc> 0
DAc 192.168.200.0/25 vlan1 0
5 As 192.168.200.128/25 <ovpn-pr1pr4-kapija.domain.loc> 1
Wireguard config
[Interface]
PrivateKey = ****************
ListenPort = 65534
Address = 10.168.200.3/32
DNS = 192.168.200.100
MTU = 1412
[Peer]
PublicKey = ****************
PresharedKey = ****************
AllowedIPs = 192.168.200.0/24, 10.167.200.0/24, 10.168.200.0/24
Endpoint = ****************:65534
PersistentKeepalive = 25
OpenVPN (relevant to routing) part of theconfig
register-dns
route-delay 4
route-method exe
route-metric 512
route 192.168.200.0 255.255.255.0
route 10.168.200.0 255.255.255.0
route 10.167.200.0 255.255.255.0
route 0.0.0.0 0.0.0.0
Traceroute from Wireguard client to OpenVPN client
Tracing route to 10.168.200.248 over a maximum of 30 hops
1 9 ms 11 ms 10 ms 10.168.200.1
2 * * * Request timed out.
3 * * * Request timed out.
Traceroute from OpenVPN client to Wireguard client
Tracing route to 10.168.200.2 over a maximum of 30 hops
1 4 ms 3 ms 3 ms 10.168.200.254
Mikrotik config:
# 2024-01-22 16:30:30 by RouterOS 7.13.2
# model = C52iG-5HaxD2HaxD
add admin-mac=48:A9:8A:62:7A:17 auto-mac=no comment=defconf name=bridge \
port-cost-mode=short protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] comment=Internet poe-out=off
/interface ovpn-server
add name=<ovpn-magacin-kapija.domain.loc> user=magacin-kapija.domain.loc
add name=<ovpn-pr1pr4-kapija.domain.loc> user=pr1pr4-kapija.domain.loc
add name=<ovpn-pr2-kapija.domain.loc> user=pr2-kapija.domain.loc
add name=<ovpn-pr5-kapija.domain.loc> user=pr5-kapija.domain.loc
add name=<ovpn-pr6-kapija.domain.loc> user=pr6-kapija.domain.loc
/interface wireguard
add comment="Wireguard VPN" listen-port=65534 mtu=1412 name=WG
/interface vlan
add comment="LAN mreza" interface=bridge name=vlan1 vlan-id=1
add comment="Buduca mreza za goste" interface=bridge name=vlan2 vlan-id=2
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment="vlan20 - wifi gosti" name=WIFI
/interface wifi channel
add band=2ghz-ax disabled=no frequency=2412 name=1 width=20mhz
add band=2ghz-ax disabled=no frequency=2437 name=6 width=20mhz
add band=2ghz-ax disabled=no frequency=2462 name=11 width=20mhz
add band=5ghz-ax disabled=no frequency=5180-5250 name=42 width=20/40/80mhz
/interface wifi
set [ find default-name=wifi1 ] channel=42 configuration.country=\
"United States" .mode=ap .ssid=**** datapath.bridge=bridge .vlan-id=1 \
disabled=no security.authentication-types=wpa2-psk .ft=yes \
.ft-mobility-domain=0x10 .wps=disable
set [ find default-name=wifi2 ] channel=1 configuration.country=\
add name=dhcp_vlan10 ranges=192.168.200.10-192.168.200.99
add name=openvpn ranges=10.168.200.130-10.168.200.253
add address-pool=dhcp_vlan10 interface=vlan1 lease-time=2w1d name=dhcp1
/port
set 0 name=serial0
/ppp profile
add change-tcp-mss=yes dns-server=192.168.200.100 interface-list=LAN \
local-address=10.168.200.254 name=openvpn only-one=yes remote-address=\
openvpn use-compression=no use-encryption=required use-ipv6=no use-mpls=\
no use-upnp=no
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=15360
/interface bridge vlan
add bridge=bridge tagged=bridge untagged=\
ether2,ether3,ether4,wifi1,wifi2,ether5 vlan-ids=1
add bridge=bridge tagged=bridge,ether2,ether3,ether4,ether5,wifi1,wifi2 \
vlan-ids=2
add comment=defconf interface=vlan1 list=LAN
add interface=WG list=LAN
/interface ovpn-server server
set auth=sha1 certificate=kapija.domain.loc cipher=aes128-cbc \
default-profile=openvpn enabled=yes netmask=25 port=587 \
require-client-certificate=yes
/interface wireguard peers
add allowed-address=10.168.200.2/32 interface=WG preshared-key=\
"********************************" public-key=\
add allowed-address=10.168.200.3/32 interface=WG preshared-key=\
add address=192.168.200.1/25 interface=vlan1 network=192.168.200.0
add address=10.168.200.1 interface=WG network=10.168.200.1
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.200.0/25 dns-server=192.168.200.100 domain=domain.loc \
gateway=192.168.200.1
set servers=192.168.200.100
established,related,untracked
add action=accept chain=input disabled=yes src-address=************
invalid
add action=accept chain=input comment=Wireguard dst-port=65534 \
in-interface-list=WAN protocol=udp
add action=accept chain=input comment=OpenVPN dst-port=587 in-interface-list=\
WAN protocol=tcp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat dst-port=37777-37778 in-interface-list=WAN \
protocol=tcp src-address=!192.168.200.0/25 to-addresses=192.168.200.25 \
to-ports=37777-37778
add action=dst-nat chain=dstnat dst-port=10000 in-interface-list=WAN \
protocol=tcp src-address=!192.168.200.0/25 to-addresses=192.168.200.1 \
to-ports=587
add distance=1 dst-address=10.167.200.32/27 gateway=\
add distance=1 dst-address=10.167.200.64/27 gateway=\
add distance=1 dst-address=10.167.200.128/27 gateway=\
add distance=1 dst-address=10.167.200.160/27 gateway=\
add distance=1 dst-address=192.168.200.128/25 gateway=\
add disabled=no dst-address=10.168.200.0/25 gateway=WG routing-table=main \
suppress-hw-offload=no
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add name=w.domain.loc profile=openvpn service=ovpn
/system clock
set time-zone-name=Europe/Belgrade
/system identity
set name=kapija.domain.loc
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
Edit:
Wireguard peer config on Mikrotik
