i setup a OpenVPN Server on a RB to connect some IoT devices with our network. The IP adresses for the IoT devices should provided via a DHCP-Server. But if i try to setup the DHCP Server i get everytime the messages DHCP invalid. Could somebody take a look to the config and could give a hint.
Thanks + Regards
# 2024-12-12 14:28:39 by RouterOS 7.15.3
# software id = W0EM-SE0S
# model = RB750Gr3
add admin-mac=D4:01:C3:87:6E:9A arp=proxy-arp auto-mac=no comment=defconf \
ingress-filtering=no name=bridge port-cost-mode=short vlan-filtering=yes
/interface ovpn-server
add name=ovpn-in1 user=""
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add name=dhcp-vpn ranges=172.20.1.10-172.20.1.100
/ppp profile
add bridge=bridge local-address=0.0.0.0 name=vpn-srv01 use-encryption=yes \
use-ipv6=no
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add addresses=0.0.0.0/0 name=lesen
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 \
internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
add bridge=bridge interface=ovpn-in1
set udp-timeout=10s
/ipv6 settings
/interface bridge vlan
add bridge=bridge untagged=ether5,bridge vlan-ids=1600
/interface ovpn-server server
set auth=sha1,md5 certificate=sww_server-cert cipher=aes128-cbc,aes192-cbc \
enabled=yes require-client-certificate=yes
192.168.88.0
add address=10.241.31.4/29 comment="xxx" interface=ether5 network=\
10.241.31.0
add address=172.31.1.11/29 comment="yyy" interface=ether1 \
network=172.31.1.8
add address=172.27.1.1/24 disabled=yes interface=ovpn-in1 network=172.27.1.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1h
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address-pool=dhcp-vpn interface=ovpn-in1 lease-time=12h name=dhcp-vpn
add address=172.20.1.0/24 gateway=172.20.1.1 netmask=24
192.168.88.1 netmask=24
add address=192.168.200.0/32 dns-none=yes gateway=192.168.200.1 netmask=25
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8,172.31.1.9
/ip dns static
add address=1.1.1.1 name=Cloudflare
established,related,untracked
add action=accept chain=input comment="accept input OpenVPN" dst-port=1194 \
in-interface-list=WAN log=yes log-prefix=ovpn protocol=tcp
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip hotspot profile
add check-gateway=ping comment="Standard Internet Route" disabled=no \
distance=1 dst-address=0.0.0.0/0 gateway=172.31.1.9 routing-table=main \
scope=30 suppress-hw-offload=no target-scope=10
add comment="MGM" disabled=no distance=1 dst-address=172.27.1.0/28 \
gateway=10.241.31.1 routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
/ppp secret
add name=c1 profile=vpn-srv01 service=ovpn
add name=c2 profile=vpn-srv01 service=ovpn
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
/system identity
set name=r-vpn
/system logging
set 0 topics=info,ovpn
add topics=debug,ovpn
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=172.31.1.9
/tool mac-server
/tool mac-server mac-winbox
