OpenVPN server inside LAN, not in router.
I need help with OpenVPN. I’m doing a site-to-site link. The particularity is that the OpenVPN server is within my LAN, so my router made a rule of re-sending port 1194 to the RB750G mikrotik and add a routing rule so that all the traffic coming from the vpn tunnel will handle it the OpenVPN server. I got the tunnel to connect and I have ping between both ends, but I can not access services or machines that are next to the client. For example, in the customer network there are ip telephones that connect perfectly to the server that is in the OpenVPN LAN network that acts as a server, but I have a one way connection from the client network to the server network. I have seen many tutorials but the example of 2 mikrotik is always addressed as routers, but not in my case where only the client is a router, but the server is within the local network. I hope you can help me configure the rules of the RB750G server.
