OpenVPN server restart causes permanent SSL CPU increase (RB4011iGS+ / RouterOS 7.13.4)
Dear Mikrotik community I have a problem:
Each time I take down and then up again the ovpn-server interface ssl takes 24% more resources: an entire new CPU core. The problem started 30m after issuing a new certificate for the server. Even during nighttime when nobody is connected the consumption does not drop. I can not switch off and on due to other services.
ssl ~24%(CPU) - off/on ovpn-server ->ssl ~50% - off/on ovpn-server -> ssl ~75%
Current situation
system resource cpu print
0 cpu0 100% 0% 0%
1 cpu1 100% 2% 0%
2 cpu2 5% 1% 0%
3 cpu3 100% 1% 0%
tool profile
ssl 74.6%
RouterOS 7.13.4
user manager 7.13.4
architecture-name: arm
board-name: RB4011iGS+
platform: MikroTik
I thank you very much for your time, any info, idea, suggestion is appreciated.
There have been over 40 stable RouterOS releases since your version, with dozens of ovpn related changes and fixes:
MikroTik · Downloads
You should first try the latest stable or long-term version to see whether the problem is still reproducible or has been already fixed.
Sometimes restart helps a lot.
There always should be maintenance "time window" scheduled to be able to upgrade/reconfigure router.
