OpenVPN setup problems
I am having hard time (two days spent trying things, googling and learning with little success) setting up OpenVPN server on my RB750 (just upgraded it from 5.2, and from some earlier bios).
I am trying to make OpenVPN server so clients can connect to a local file server (FS resides on 192.168.1.x network).
So here is what i did (omited some useless info):
[admin@MikroTik] /interface bridge port> /ip pool print
 # NAME                                         RANGES
 0 default-dhcp                                 192.168.1.10-192.168.1.254
 1 VPN01                                        192.168.4.10-192.168.4.20
[admin@MikroTik] /ppp profile> print
 1   name="OpenVPN1-in" local-address=192.168.4.1 remote-address=VPN01
     use-mpls=default use-compression=default use-vj-compression=default
     use-encryption=required only-one=default change-tcp-mss=default
[admin@MikroTik] > /ppp secret print
 #   NAME       SERVICE CALLER-ID      PASSWORD      PROFILE      REMOTE-ADDRESS
 1   -          ovpn                   -             OpenVPN1-in
(u/p for testing only)
[admin@MikroTik] /ppp> /interface ovpn-server server print
                     enabled: yes
                        port: 1194
                        mode: ethernet
                     netmask: 24
                 mac-address: FE:B5:6C:46:0F:00
                     max-mtu: 1500
           keepalive-timeout: disabled
             default-profile: OpenVPN1-in
                 certificate: ServerCert
  require-client-certificate: no
                        auth: sha1,md5
                      cipher: blowfish128,aes128,aes192,aes256
[admin@MikroTik] /ip firewall filter> print
 4   ;;; OpenVPN
     chain=input action=accept protocol=tcp dst-port=1194
I generated certificates and inported them and that part seems to be working. So now comes the client (Windows 7).
client.ovpn content:
dev tap
proto tcp-client
remote xxx.xxx.xxx.xxx 1194
resolv-retry infinite
nobind
persist-key
tls-client
ca ca.crt
cert client1.crt
key client1.key
auth-user-pass
verb 3
ping 10
cipher AES-256-CBC
auth SHA1
pull
auth-nocache
;script-security 2 system -- tried that, not much help
;route-up "route add 192.168.1.0 mask 255.255.255.0 192.168.4.1" -- tried that, not much help
And what i get out of log:
Sun Jun 10 20:42:25 2012 OpenVPN 2.2-beta3 i686-pc-mingw32 [SSL] [LZO2] [PKCS11] built on Sep  2 2010
Sun Jun 10 20:42:28 2012 WARNING: --ping should normally be used with --ping-restart or --ping-exit
Sun Jun 10 20:42:28 2012 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Sun Jun 10 20:42:28 2012 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sun Jun 10 20:42:28 2012 NOTE: --script-security method='system' is deprecated due to the fact that passed parameters will be subject to shell expansion
Sun Jun 10 20:42:28 2012 Control Channel MTU parms [ L:1591 D:140 EF:40 EB:0 ET:0 EL:0 ]
Sun Jun 10 20:42:28 2012 Socket Buffers: R=[8192->8192] S=[8192->8192]
Sun Jun 10 20:42:28 2012 Data Channel MTU parms [ L:1591 D:1450 EF:59 EB:4 ET:32 EL:0 ]
Sun Jun 10 20:42:28 2012 Local Options hash (VER=V4): 'b60e7885'
Sun Jun 10 20:42:28 2012 Expected Remote Options hash (VER=V4): 'fbeb66e6'
Sun Jun 10 20:42:28 2012 Attempting to establish TCP connection with xxx.xxx.xxx.xxx:1194
Sun Jun 10 20:42:28 2012 TCP connection established with xxx.xxx.xxx.xxx:1194
Sun Jun 10 20:42:28 2012 TCPv4_CLIENT link local: [undef]
Sun Jun 10 20:42:28 2012 TCPv4_CLIENT link remote: xxx.xxx.xxx.xxx:1194
Sun Jun 10 20:42:28 2012 TLS: Initial packet from xxx.xxx.xxx.xxx:1194, sid=404b35c7 eaf40f1d
Sun Jun 10 20:42:29 2012 VERIFY OK: depth=1, /C=_andsoon_
Sun Jun 10 20:42:29 2012 VERIFY OK: depth=0, /C=_andsoon_
Sun Jun 10 20:42:30 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sun Jun 10 20:42:30 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Jun 10 20:42:30 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sun Jun 10 20:42:30 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Jun 10 20:42:30 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Sun Jun 10 20:42:30 2012 [ovpn-server] Peer Connection Initiated with xxx.xxx.xxx.xxx:1194
Sun Jun 10 20:42:33 2012 SENT CONTROL [ovpn-server]: 'PUSH_REQUEST' (status=1)
Sun Jun 10 20:42:38 2012 SENT CONTROL [ovpn-server]: 'PUSH_REQUEST' (status=1)
Sun Jun 10 20:42:43 2012 SENT CONTROL [ovpn-server]: 'PUSH_REQUEST' (status=1)
Sun Jun 10 20:42:43 2012 PUSH: Received control message: 'PUSH_REPLY,route-gateway 192.168.4.1,ifconfig 192.168.4.20 255.255.255.0'
Sun Jun 10 20:42:43 2012 OPTIONS IMPORT: --ifconfig/up options modified
Sun Jun 10 20:42:43 2012 OPTIONS IMPORT: route-related options modified
Sun Jun 10 20:42:43 2012 TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{D72FDF0E-5635-4484-99E9-95C150E2345E}.tap
Sun Jun 10 20:42:43 2012 TAP-Win32 Driver Version 9.8
Sun Jun 10 20:42:43 2012 TAP-Win32 MTU=1500
Sun Jun 10 20:42:43 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 192.168.4.20/255.255.255.0 on interface {D72FDF0E-5635-4484-99E9-95C150E2345E} [DHCP-serv: 192.168.4.0, lease-time: 31536000]
Sun Jun 10 20:42:43 2012 Successful ARP Flush on interface [16] {D72FDF0E-5635-4484-99E9-95C150E2345E}
Sun Jun 10 20:42:48 2012 TEST ROUTES: 0/0 succeeded len=-1 ret=1 a=0 u/d=up
Sun Jun 10 20:42:48 2012 Initialization Sequence Completed
And ipconfig:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-Win32 Adapter V9
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IPv4 Address. . . . . . . . . . . : 192.168.4.20(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 10. junij 2012 20:50:08
   Lease Expires . . . . . . . . . . : 10. junij 2013 20:50:07
   Default Gateway . . . . . . . . . :
   DHCP Server . . . . . . . . . . . : 192.168.4.0
   DHCPv6 IAID . . . . . . . . . . . : 469827543
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-44-FC-01-00-22-15-37-14-22
   DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Why is there no gateway, and how come dhcp is set to 192.168.4.0
If you need any more info, i can post that too. As long as this thing finally gets working.
Any help would be usefull as i am at a loss…
Any help would be usefull. What am i missing?
How come noone knows what is wrong.
This isn’t supposed to be some strange setting, it is supposed to be a normal feature of RouterOS, no?
OpenVPN is quite unsupported by MT, no matter what they say: support only parts of ovpn features (forcing use of settings that MT software recognize, that’s not a definition of “interoperability”), no proper documentation (wiki page is a shame).
It takes me 10 mins to get an openVPN linux server up (CA + client certificates creation included), with MT I only manage to get my pppoe (client) WAN link messed up (WTH? once, I even got a second IP address from my ISP…).
I’ll make a new thread about this when I’ll be able to sum it up without ranting too much aggressively.
