Hi
I am trying to configure openvpn server but its not working. I have done everything they shown on the site but the vpn is not running. Can anybody help? Here is my server config
/ip address add address=192.168.1.2/24 interface=ether2 comment=Internet
/ip route add gateway=192.168.1.254 comment=Internet
/ip firewall nat add chain=srcnat out-interface=ether2 action=masquerade
/ip pool add name=ovpn-pool ranges=10.200.225.30-10.200.225.60
/ppp profile
add change-tcp-mss=default comment=“” local-address=10.200.225.29
name=“openvpn” only-one=default remote-address=ovpn-pool
use-compression=default use-encryption=required use-vj-compression=default
/ppp secret
add caller-id=“” comment=“” disabled=no limit-bytes-in=0
limit-bytes-out=0 name=“name” password=“password”
routes=“” service=any
/interface ovpn-server server
set auth=sha1,md5 certificate=cert1
cipher=blowfish128,aes128,aes192,aes256 default-profile=openvpn
enabled=yes keepalive-timeout=disabled max-mtu=1500 mode=ip netmask=24
port=1194 require-client-certificate=no
add action=accept chain=input comment=“OpenVPN” disabled=no dst-port=1194 protocol=tcp
