Hi all,
I keep coming across this problem / bug whereby OpenVPN stops responding.
I have it all setup fine and working, but it is in an experimental stage. From time to time I’m changing something like the certificate, or possibly moving from port 1194 to port 443. I find that often when I make a change via Winbox to the OpenVPN config, OpenVPN stops responding until I reboot. I try to rectify by disabling and enabling OpenVPN, reverting the change, etc, but nothing works except a reboot.
I’m getting the same results with 3.19 and 3.22.
Rich
