OpenVPN suddenly stopped working
Hello!
About a month ago or so I set up OpenVPN on our Mikrotik router running v6.42.3. Everything has been working dandy until today, were I suddenly cannot connect.
My windows client OpenVPN GUI says the following:
Mon Jan 21 19:10:43 2019 OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 26 2018
Mon Jan 21 19:10:43 2019 Windows version 6.2 (Windows 8 or greater) 64bit
Mon Jan 21 19:10:43 2019 library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10
Mon Jan 21 19:10:43 2019 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Mon Jan 21 19:10:43 2019 Need hold release from management interface, waiting…
Mon Jan 21 19:10:44 2019 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Mon Jan 21 19:10:44 2019 MANAGEMENT: CMD ‘state on’
Mon Jan 21 19:10:44 2019 MANAGEMENT: CMD ‘log all on’
Mon Jan 21 19:10:44 2019 MANAGEMENT: CMD ‘echo all on’
Mon Jan 21 19:10:44 2019 MANAGEMENT: CMD ‘bytecount 5’
Mon Jan 21 19:10:44 2019 MANAGEMENT: CMD ‘hold off’
Mon Jan 21 19:10:44 2019 MANAGEMENT: CMD ‘hold release’
Mon Jan 21 19:10:45 2019 MANAGEMENT: CMD ‘username “Auth” “MYUSERNAME”’
Mon Jan 21 19:10:45 2019 MANAGEMENT: CMD ‘password […]’
Mon Jan 21 19:10:45 2019 WARNING: this configuration may cache passwords in memory – use the auth-nocache option to prevent this
Mon Jan 21 19:10:45 2019 MANAGEMENT: >STATE:1548094245,RESOLVE,
Mon Jan 21 19:10:45 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]OUR-EXTERNAL-IP:1194
Mon Jan 21 19:10:45 2019 Socket Buffers: R=[65536->65536] S=[65536->65536]
Mon Jan 21 19:10:45 2019 Attempting to establish TCP connection with [AF_INET]OUR-EXTERNAL-IP:1194 [nonblock]
Mon Jan 21 19:10:45 2019 MANAGEMENT: >STATE:1548094245,TCP_CONNECT,
Mon Jan 21 19:10:46 2019 TCP connection established with [AF_INET]OUR-EXTERNAL-IP:1194
Mon Jan 21 19:10:46 2019 TCP_CLIENT link local: (not bound)
Mon Jan 21 19:10:46 2019 TCP_CLIENT link remote: [AF_INET]OUR-EXTERNAL-IP:1194
Mon Jan 21 19:10:46 2019 MANAGEMENT: >STATE:1548094246,WAIT,
Mon Jan 21 19:10:46 2019 Connection reset, restarting [-1]
Mon Jan 21 19:10:46 2019 SIGUSR1[soft,connection-reset] received, process restarting
Mon Jan 21 19:10:46 2019 MANAGEMENT: >STATE:1548094246,RECONNECTING,connection-reset,
Mon Jan 21 19:10:46 2019 Restart pause, 5 second(s)
And then it loops for that like eternity. I have tried from 2 different computers, both known to be working before, from my ISP and my cellphones LTE connection.
Logging under RouterOS does not say anything despite me running:
/system logging
add topics=ovpn,debug
Any ideas?
Regards, Emil
Looks like the connection attempt is being rejected from your router. Is your ovpn server still running?
Did you apply any changes to your input firewall before that?
Yupp, I even tried to restart it (by web interface untick running box, apply, tick it again, apply)
Nope, nothing should have been touched from the last time it was working.
Here’s our firewall rules: https://i.imgur.com/vpJlQUS.png
With black marker being an AWS VPN IP-address and the blue marker being our external IP-address.
