Hello, I'm configuring OpenVPN + MFA using OpenTOP. Using AI, I've been refining and adjusting parameters, but I've run into a problem. If the user approves the connection quickly, everything works fine. However, if they take 10-15 seconds, I see in "active connections" that the connection has been approved, but the OpenVPN client doesn't register it and sends the request again.
I've been analyzing and consulting, and according to AI, it's an issue with the OpenVPN server. Their explanation:
"In MikroTik, the OpenVPN server (ovpn-server) isn't managed in isolation, but rather runs in the background within the PPP subsystem (just like L2TP or PPTP).
The RouterOS PPP daemon has a strict internal timeout for the authentication phase (usually around 3 to 5 seconds). This is what happens chronologically when you take 15 seconds:
The PC requests a connection. MikroTik freezes the session and sends a RADIUS request to WebADM.
5 seconds pass. The MikroTik PPP subsystem gets tired of waiting, internally declares the negotiation thread expired, and stops listening to the client on your PC.
After 15 seconds, you tap "Approve" on your mobile device.
WebADM responds to MikroTik with a RADIUS packet." Access-Accept (Access Granted).
Here's the MikroTik flaw: The router's RADIUS client receives the "OK," blindly accepts it, and takes the user to the Active Connections tab. However, since the original PPP negotiation thread with the PC had already closed after 5 seconds, the router never sends the final confirmation packet to the PC.
How can I fix this? If I'm quick, everything works fine, but if the user is slow or their phone is far away, the connection drops. I need a 30-second window where, if the connection is approved, the client is notified. How can I do this with MikroTik?
