Ok, I’ve entered created and uploaded and imported the server side certificate and client side certificate.
The server is now telling me that a connection is established, however, the OVPN client and server status is disconnected.
I must be missing something really silly here. Please help.
Kindly see below:
SERVER
ppp secret:
name=“username” service=ovpn caller-id=“” password=“password” profile=default routes=“” limit-bytes-in=0 limit-bytes-out=0
Ovpn Pool:
2 ovpn-pool 10.15.32.34-10.15.32.38
PPP Profile:
ppp profile print
Flags: * - default
0 * name=“default” use-compression=default use-vj-compression=default use-encryption=default only-one=default change-tcp-mss=yes
1 name=“Beya_Voip” local-address=10.15.32.33 remote-address=ovpn-pool use-compression=default use-vj-compression=default
use-encryption=required only-one=default change-tcp-mss=default
Ovpn-Server Server:
interface ovpn-server server print
enabled: yes
port: 443
mode: ip
netmask: 29
mac-address: FE:50:A6:C5:67:B9
max-mtu: 1500
keepalive-timeout: disabled
default-profile: Beya_Voip
certificate: cert1
require-client-certificate: yes
auth: sha1,md5
cipher: blowfish128,aes128,aes192,aes256
CLIENT
interface ovpn-client print detail
0 name=“ovpn-out1” mac-address=FE:84:A8:9E:19:43 max-mtu=1500 connect-to=172.16.0.1 port=443 mode=ip user=“username”
password=“password” profile=default certificate=cert1 auth=sha1 cipher=aes256 add-default-route=no
LOG
21:43:01 ovpn,info TCP connection established from W.X.Y.Z
21:43:02 ovpn,info TCP connection established from W.X.Y.Z
21:43:05 ovpn,info TCP connection established from W.X.Y.Z
PING from Client:
ping 10.15.32.33
10.15.32.33 ping timeout
