First off all I’m sorry for my bad English
I am installed mikrotik version 5.6 and done all of thing for ovpn server configurations.
Everything is done. But I have unusual error.
When I connect from my pc with openvpn to my server its work, I can search, download without problem, and after I checked openvpn is working, I send config files to my friends to check is it working?
Here is my problem:
server side:
16:50:55 ovpn,info : dialing…
16:51:55 ovpn,info : terminating… - could not negotiate TLS in time
16:51:55 ovpn,info : disconnected
client side:
Sun Oct 09 20:21:44 2011 TCPv4_CLIENT link local: [undef]
Sun Oct 09 20:21:44 2011 TCPv4_CLIENT link remote: 31.3.238.149:2106
Sun Oct 09 20:21:45 2011 TLS: Initial packet from 31.3.238.149:2106, sid=dcfe38ae cb38bcff
You might think hey that is firewall problem but it isn’t!
Here the reasons:
- One pc can’t connect to server (firewall is off)
Above problem
When connect pc to my modem, the pc connected successfully.
I think maybe modem has problem then I decided to change modem but it’s not worked.
I reset modem and set again pppoe and try to connect, bingo it’s connected.
Yes modem has a problem
But when I saw this problem in another pc I try to reset modem and connect to server but it’s not working.
I think maybe I must change MTU but not worked.
What is the problem:double_exclamation_mark:
Some people can connect but some people can’t connect
Finally:
A: maybe mikrotik has a problem with openvpn – 70%
B: maybe ISP has a problem – 10% - because some people have same ISP registration .for some work.
C: maybe some modem has problem – 2% - because I changed modem but still not worked.
