Getns, I have managed to create ovpn client from Mikrotik device to my Debian server.
I have created interface virtAP (5GHz) and assigned subnet 10.10.20.0/24 to it; DHCP server as well…
when I connect to my virtAP I get address from 10.10.20.0/24 pool.
now I need to route my 10.10.20.0/24 thru openvpn tunel…
My penvpn interface on Mikrotik router is up and running: connected
my Debian openvpn config:
# cat /etc/openvpn/openvpn.conf
port 443
proto tcp
dev tun
ca ca.crt
cert serverJB.crt
key serverJB.key
dh dh2048.pem
server 10.10.0.0 255.255.255.0
cipher AES-256-CBC
user nobody
group nogroup
status /var/log/openvpn-status.log
log-append /var/log/openvpn
verb 3
mute 0
max-clients 100
keepalive 10 120
persist-key
persist-tun
push "redirect-gateway def1"
push "dhcp-option DNS 8.8.8.8"
push “dhcp-option DNS 8.8.4.4″
# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ACCEPT all -- 10.10.0.0/24 anywhere
REJECT all -- anywhere anywhere reject-with icmp-port-unreachable
Chain OUTPUT (policy ACCEPT)
# ifconfig tun0
tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.10.0.1 P-t-P:10.10.0.2 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:1052 errors:0 dropped:0 overruns:0 frame:0
TX packets:164 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:142747 (139.4 KiB) TX bytes:13300 (12.9 KiB)
I will share Mikrotik config later…
I also have 2 APs with subnet 172.17.1.0/24…it is for my wifi users to go via local ISP with NAT on vlan11…
from ISP I have trunk port (ether1) 2 vlans FROM ISP:
VLAN 11 is intenet
VLAN 13 is for IPTV multicast…
I have followed this guide to manage openvpn server & client on MIkrotik:
http://forum.mikrotik.com/t/tutorial-mikrotik-ovpn-client-as-gateway-interface/72140/1
which way You suggest to go to route my virtAP subnet 10.10.20.0/24 thru openvpn server ?
Thank You!
