OpenVPN with UDP not working beta3
HW: mAP Lite
ROS: 7.0beta3
OpenVPN UDP: The connection to the server occurs, but it is not navigated through the VPN.
Configuration:
[admin@rt01_v7] > /export hide-sensitive
# oct/24/2019 09:40:35 by RouterOS 7.0beta3
# software id =
# model = RouterBOARD mAP L-2nD
# serial number = 73B207163703
add fast-forward=no name=loopback600 protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/ip hotspot profile
/ppp profile
add local-address=172.18.0.1 name=pVPN remote-address=172.18.0.2 use-ipv6=no use-mpls=no use-upnp=no
/interface ovpn-server server
set auth=sha1 certificate=server_ovpn.crt cipher=aes128,aes192,aes256 default-profile=pVPN enabled=yes port=1198 protocol=udp \
    require-client-certificate=yes
add address=192.168.134.1 interface=loopback600 network=192.168.134.1
/ip dhcp-client
add dhcp-options=clientid,clientid_duid,hostname disabled=no interface=ether1
add action=masquerade chain=srcnat out-interface=all-ppp
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip service
set www-ssl certificate=www-ssl.crt disabled=no
#error exporting /ipv6/route/rule
/ppp secret
add name=ops12 profile=pVPN service=ovpn
#error exporting /routing/policy/selection
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=rt01_v7
/system package update
set channel=development
Logs:
09:54:30 ovpn,debug <X.X.X.X>: disconnected
Captures:
Regards.
Works for me on RB750. Disregard IPSec parts in config below.
Didn't have time to test TCP vs. UDP speed but i have done upload to RPi (1b+) which act as test server behind VPN and it gained solid 2MB/sec with
processor load between 5 and 75%
[admin@Test-Slave] > /export hide-sensitive
oct/27/2019 18:40:26 by RouterOS 7.0beta3
model = 750G
serial number = 268D01789F7A
/ip ipsec mode-config
add name=Test-cfg responder=no src-address-list=test
/ip ipsec profile
add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha256 name=FirmaEN nat-traversal=no
/ip ipsec peer
add address=192.168.0.254/32 disabled=yes exchange-mode=ike2 local-address=192.168.52.1 name=FirmaEN profile=FirmaEN
/ip ipsec proposal
add auth-algorithms=sha256 disabled=yes enc-algorithms=aes-256-cbc lifetime=1h name=FirmaEN pfs-group=modp2048
add name=local ranges=192.168.62.1-192.168.62.10
add name=OpenVPN ranges=192.168.54.1-192.168.54.10
add address-pool=local disabled=no interface=ether2 name=local
/ppp profile
add change-tcp-mss=yes local-address=192.168.54.254 name=OpenVPN remote-address=OpenVPN use-encryption=yes
set auth=sha1 certificate=test2-gw.crt_0 cipher=aes256 default-profile=OpenVPN enabled=yes protocol=udp require-client-certificate=yes
add address=192.168.52.1/24 interface=ether1 network=192.168.52.0
add address=192.168.62.254/24 interface=ether2 network=192.168.62.0
add address=192.168.63.10 disabled=yes interface=ether3 network=192.168.63.10
add address=192.168.62.0/24 dns-server=192.168.62.254 gateway=192.168.62.254 netmask=24
set allow-remote-requests=yes servers=192.168.0.254
/ip firewall address-list
add address=192.168.62.0/24 list=test
add action=src-nat chain=srcnat dst-address=10.200.222.2 protocol=icmp to-addresses=192.168.62.1
/ip ipsec identity
add disabled=yes peer=FirmaEN
/ip ipsec policy
add disabled=yes dst-address=10.200.222.2/32 peer=FirmaEN proposal=FirmaEN protocol=icmp src-address=192.168.62.1/32 tunnel=yes
add disabled=yes dst-address=10.200.222.2/32 dst-port=22 peer=FirmaEN proposal=FirmaEN protocol=tcp src-address=192.168.62.1/32 tunnel=yes
add dst-address=0.0.0.0/0 gateway=192.168.52.254
/ppp secret
add name=sbaksa profile=OpenVPN service=ovpn
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name=Test-Slave
/system leds
add leds=user-led type=on
/system ntp client
set enabled=yes
/system ntp client servers
add address=161.53.123.5
add address=161.53.160.5
Description
Device: mAPLite
Version: v7.0beta4
Issue: OpenVPN with UDP not working.
UDP does not work properly, you can connect, but you do not browse, and it disconnects only within a few seconds.
Hi, I am using a Mikrotik router so as to connect to my remote network through OpenVpn UDP protocol, I used RouterOS 7 beta, it connects but there is no route to Internet, can someone check my configs to see if there is any problem ?
I can’t use TCP protocol, so do you think isntalling OpenWRT on the router could be a better solution ?
