I managed to setup OpenVPN on my CCR and was able to setup OpenVPN on Android. An almost identical configuration on iOS doesn’t seem to work. I get a rather cryptic message from the OpenVPN client on it:
2015-12-14 16:18:31 Client exception in transport_recv_excode: PolarSSL: SSL read error : SSL - A fatal alert message was received from our peer
2015-12-14 16:18:31 Client terminated, restarting in 2...
2015-12-14 16:18:33 EVENT: RECONNECTING
2015-12-14 16:18:33 EVENT: RESOLVE
2015-12-14 16:18:33 Contacting <router-ip>:1194 via TCP
2015-12-14 16:18:33 EVENT: WAIT
2015-12-14 16:18:33 SetTunnelSocket returned 1
2015-12-14 16:18:33 Connecting to <router-ip>:1194 (<router-ip>) via TCPv4
2015-12-14 16:18:33 EVENT: CONNECTING
2015-12-14 16:18:33 Tunnel Options:V4,dev-type tun,link-mtu 1559,tun-mtu 1500,proto TCPv4_CLIENT,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-client
2015-12-14 16:18:33 Peer Info:
IV_GUI_VER=net.openvpn.connect.ios 1.0.5-177
IV_VER=3.0
IV_PLAT=ios
IV_NCP=1
I can’t seem to enable enough debugging on the CCR to know what’s going on:
16:52:06 ovpn,info TCP connection established from <client ip>
16:52:06 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=0ff3c66224a6742 pid=0 DATA len=0
16:52:06 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=8d2c8f58d9b5fd2c pid=0 DATA len=0
16:52:06 ovpn,debug,packet sent P_ACK kid=0 sid=0ff3c66224a6742 [0 sid=8d2c8f58d9b5fd2c] DATA len=0
16:52:06 certificate,debug start CRL update
16:52:06 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=8d2c8f58d9b5fd2c [0 sid=0ff3c66224a6742] pid=1 DATA len=0
16:52:06 ovpn,debug,packet sent P_ACK kid=0 sid=0ff3c66224a6742 [1 sid=8d2c8f58d9b5fd2c] DATA len=0
16:52:06 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=8d2c8f58d9b5fd2c pid=2 DATA len=74
16:52:06 ovpn,debug,packet sent P_ACK kid=0 sid=0ff3c66224a6742 [2 sid=8d2c8f58d9b5fd2c] DATA len=0
16:52:06 ovpn,debug,packet sent P_CONTROL kid=0 sid=0ff3c66224a6742 pid=1 DATA len=7
16:52:06 ovpn,debug <<client ip>>: disconnected <TLS failed>
My OpenVPN client config is this:
dev tun
proto tcp-client
remote <public router IP> 1194 # Remote OpenVPN Servername or IP address
tls-client
port 1194
#user nobody
#group nogroup
#comp-lzo # Do not use compression. It doesn't work with RouterOS (at least up to RouterOS 3.0rc9)
# More reliable detection when a system loses its connection.
ping 15
ping-restart 45
ping-timer-rem
persist-tun
persist-key
# Silence the output of replay warnings, which are a common false
# alarm on WiFi networks. This option preserves the security of
# the replay protection code without the verbosity associated with
# warnings about duplicate packets.
mute-replay-warnings
# Verbosity level.
# 0 = quiet, 1 = mostly quiet, 3 = medium output, 9 = verbose
verb 9
cipher AES-256-CBC
auth SHA1
pull
route <internal network> 255.255.255.0
push "route <internal network> 255.255.255.0"
push "dhcp-option DNS <internal router IP>"
push "dhcp-option DOMAIN <internal domain>"
<ca>
</ca>
<cert>
</cert>
<key>
</key>
I tried both including the cert/keys in the config file as well as using iOS’s certificate store, but ended up with the same errors.
Is there any way to get even more logging from the CCR and/or anyone have suggestions on what may be going on here?
