OpenVPN
In the past i used and tplink archer c7 and succesfull create an openvpn server. I just wana create on the mikrotik router too. My ppoe connection its direct on the mikrotik router, i have hap ac .
  • created certificates and sign it.
  • created a pool named openvpn with addresses : 10.8.0.2 - 10.8.0.40 i let the 10.8.0.1 to be the server
  • i succesful enabled the openvpn via ppp->openvpn.
  • i saw many tutorial on youtube. i just wana connect via my dns(dns its offered by the provider) to openvpn server.
  • i just make same nat rules, but i cannot connect to the openvpn server.
    Can someone explain me please what firewall rules to apply to can connect to the openvpn server via my dns? Yes, i know i`m new (nub) on this router and i dont have to many skills, but i just try to learn.
    my router ip is 192.168.0.1
    Thanks a lot,
    Edy
Your IP address 192.168.x.x is a private one - no one will be able to reach it. Your ISP is doing NAT (or CGNAT).
Try to get a public IP address, or see if your ISP do a port forward to you (highly unlikely, but worth a try).
NAT
my internal ip is 192.168.x.x, on the tplink i have an option called DMZ which make my internal ip to can pe access from public ip. so if i have 192.168.0.1 and i enable dmz my router can be accessed from my public address. if worked on ddwrt with tplink archer should work here too,but its a little but to complicate for me and i dono what NAT to do. the problem is i cannot connect not even on local address. thanks for reply.
be more specific , i know i need to make NAT. thanks for reply
