OPENVPN
I have a PFSENSE 23.05 OPENVPN SERVER these are the LOGS:
 TLS error: Unsupported protocol. This typically indicates that client and server have no common TLS version enabled. This can be caused by mismatched tls-version-min and tls-version-max options on client and server. If your OpenVPN client is between v2.3.6 and v2.3.2 try adding tls-version-min 1.0 to the client configuration to use TLS 1.0+ instead of TLS 1.0 only
 OpenSSL: error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol
When a MIKROTIKROS 7.10.2 OPENVPN CLIENT try to connect:
ovpn-out1: connecting...
ovpn-out1: initializing...
ovpn-out1: using encoding - AES-128-CBC/SHA1
PUSH_REPLY,comp-lzo no,route 192.168.208.0 255.255.255.0>
IV_PROTO=746
warning: recvd <WIV_CIPHERS=AES-128-CBC:AES-128-CFB1:AES-128-CFB8:AES-128-OFB:AES-128-GCM
ovpn-out1: disconnected <peer disconnected>
ovpn-out1: terminating... - peer disconnected
Try to match the “Allowed Data Encryption Algorithm” in the PFSense side to a cipher that is supported by Mikrotik, and reflect that changes on the config in client side.
Thanks with:
custom options on server:
tls-version-min 1.2;
tls-version-max 1.2;
and TLS Version: only v.1.2 on mikrotik
the status goes to connected.
After the client is connected it get a dinamyc address (6) which is wrong, I expected the (5) as correct:
ip/address/print
#   ADDRESS           NETWORK      INTERFACE
6 D 10.7.50.6/32      10.7.50.5    ovpn-out1
5 X 10.7.50.2/32      10.7.50.0    ovpn-out1
I’ve tried an option config on the server to force the correct ip but seems to be ignored:
ifconfig-push 10.7.50.2 255.255.255.0;
Now I get the ROS clients that can access remote LAN and this is fine.
But from main site LAN could it be that server use a wrong route to get to the ROS clients:
Destination Gateway Flags USES
ROSLAN/24 10.7.50.2 ugs 15
anyway it’s the server that manage the routes, now on the client I get:
           dest                     gateway           distance
DAv+ SITEa.a.a.0/24   tunnel.client        1
DAC  tunnel.0/24         ovpn-out              0
and on the server:
tunnel.0/24             link#18
tunnel.server          link#18
SITEb.b.b.0/24       tunnel.server
and it works!
