OpenVPN
Maybe it would be worth to consider implementing OpenVPN in 2.1 or 2.x.
I would definitely vote for that
it’s on the wish list, maybe in v3 it will be made
I havent looked into OpenVPN much, but if it’s OPEN why can’t it talk with the standard VPN protocols as well? : )
Sam
Different kind of beast - OpenVPN is basically a SSL-based VPN solution.
But a good one, for several scenarios. One of the sexy things is that you can get it through almost every firewall - you just need to open a single port…
Best regards,
Christian Meis
One more vote for OpenVPN. Also work throughout proxy try some other VPN solution but this work almost on any place only need one port open to work.
Best regards.
you have my vote as well, many cellular carriers will not allow VPN traffic through your data service without paying additional fees, a SSL VPN would be nice.
must have!
already in development
Hope add in 3.0
YES! see above post
Yes, OpenVPN support would be nice?
Maybe v3beta6 includes that??? :sunglasses:
as normis said it is in development but there will be no other deadline other than stable 3.0 hope it gets faster, but it only depends on MT programmers :slight_smile: when they manage to get code stable enough.
so patience.. :blush:
Any have a “how to” guide about Openvpn and mikrotik conections?
i need connect my computer to a remote mikrotik router.
Cya! and thanks.
if you read this thread carefully, you will see that openvpn is not supported by RouterOS right now.
oh! tank you and sorry.. im from argentina and my inglish is not good. thanks a lot for answer and sorry for disturb the people.
Is there any update on this available?
Thank you
Ekkehard
It looks like in Ros beta8 supports OpenVPN
you can access it in console:
/interface ovpn-server
/interface ovpn-client
with what packages?
with ppp package
