Mikrotik RB-750GL
RouterOS 6.25
I am trying to configure OpenVPN using services provided by FreedomVPN (freedomvpn.info).
I had managed to install PPTP VPN services from strongvpn and working fine, the reason I wish to switch to FreedomVPN is because FreedomVPN allows me to switch country without changing the servers. My Amazon FireTV is current not able to root so I have to provide OpenVPN services from the router.
FreedomVPN just provide me the
- certificate.crt file
- a-server-file.ovpn
- a login name and a password.
I managed to import the .crt file into the RouterOS 6.25 via Winbox but after that I stuck as I cannot get the OpenVPN clients to connect.
any suggestion. Below is the content of the .ovpn file. If I could get this up and running it would be great.
Regards
ngcyee
Malaysia, Kuala Lumpur.
########This is the configuration file for FreedomVPNs VPN Servers#######
#DO NOT CHANGE ANYTHING INSIDE THIS FILE OR YOU WON’T BE ABLE TO CONNECT#
client
dev tun
proto udp
remote cl.freedomvpn.info 1195
resolv-retry infinite
nobind
persist-key
persist-tun
ca FVPN-Certificate.crt
auth-user-pass
cipher BF-CBC
comp-lzo
verb 3
mute 20
