OpenWRT on Mikrotik
The RouterOS IPv6 support is not enough for me, so I need Linux kernel 4.x functions. The OpenWRT 18.06.2 use Linux kernel version 4.9 or 4.14.
I found a list, which devices are supported: https://openwrt.org/toh/start?dataflt[Brand*~]=MikroTik
How do I install OpenWRT?
How do I reinstall the RouterOS if I don’t like it? How do I save the original license key? Other important?
This is not an OpenWRT forum…but you can export / import licence through system menu.
Regarding install check their forums, but probably some variation on netinstall process.
Most devices (exclude ARM based) are more or less supported…
Switching between ROS and OpenWRT is not the much work…
