I’m fairly new to Mikrotik and I’ve been trying to burn the Openwrt firmware on my RB2011UAS-2HnD router.
I don’t have a serial cable (yet) so I’ve been trying to use ether boot to burn the firmware.
I’m using a virtual machine with Ubuntu on it, it has a bridged connection with my host machine.
Ubuntu is running dnsmasq with a DHCP and TFTP server, I’ve followed the dnsmasq configuration from this tutorial:
http://wiki.openwrt.org/toh/mikrotik/rb433
When I hold down the RESET button after ~20 seconds the LCD screen says “ether boot”, and then randomly restarts and goes into normal mode without loading the ramdisk, I have no clue why it does this.
After it restarts normally, the LCD shows it has successfully been assigned the IP address 192.168.6.101, which is correct according to the manual.
(At this point I am able to PING the router, but can’t telnet it?)
Which leaves me to think my DHCP server is working, but my TFTP server isn’t.
I also keep getting this message in my /var/log/syslog
Nov 14 16:59:50 ubuntu dnsmasq-dhcp[2911]: BOOTP(eth0) d4:ca:6d:ec:09:d8 no address configured
Snippets from my dnsmasq config:
interface=eth0
dhcp-range=192.168.6.100,192.168.6.119,12
dhcp-host=d4:ca:6d:ec:09:d9,192.168.6.101
enable-tftp
tftp-root=/tftpboot
dhcp-boot=/tftpboot/openwrt.elf,boothost,192.168.6.1
Host settings:
IP address: 192.168.6.1
Broadcast Address: 192.168.6.255
Subnet Mask: 255.255.255.0
Default Route: 192.168.6.101
Primary DNS: 192.168.6.101
Router LCD:
user: admin
password:
local ip: 192.168.88.1
ether1-gateway: 192.168.6.101
ifconfig:
thom@ubuntu:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:0c:29:35:52:18
inet addr:192.168.6.1 Bcast:192.168.6.255 Mask:255.255.255.0
inet6 addr: fe80::20c:29ff:fe35:5218/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:13282 errors:0 dropped:0 overruns:0 frame:0
TX packets:2370 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1201201 (1.2 MB) TX bytes:204101 (204.1 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2873 errors:0 dropped:0 overruns:0 frame:0
TX packets:2873 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:262974 (262.9 KB) TX bytes:262974 (262.9 KB)
Been stuck for a while now, I would appreciate it if anyone here could help me.
Thank you
