Anyone heard if this can be done? I have tried to build the kamikaze trunk for the AR71xx but the ethernet ports are not found during the ag71xx_mdio: probe on bootup. I know it’s been done on the RB433 but the 493 has an IP178c switch chip, not the more familiar IP175c–that may be the problem.
I have the RB493AG up and running as a switch and wireless AP using RouterOS 3.15 level 5 and it’s working fine, but I’d really like to run kamikaze.
Rob
Here’s my dmesg:
root@OpenWrt:/# dmesg
Linux version 2.6.26.7 (rob@Server) (gcc version 4.1.2) #1 Tue Oct 28 01:02:38 E
DT 2008
prom: fw_arg0=00000007, fw_arg1=a0861c00, fw_arg2=00000000, fw_arg3=00000000
MyLoader: sysp=ffffffff, boardp=ffffffff, parts=ffffffff
console [early0] enabled
CPU revision is: 00019374 (MIPS 24K)
Determined physical RAM map:
memory: 08000000 @ 00000000 (usable)
Entering add_active_range(0, 0, 32768) 0 entries of 256 used
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0 -> 32768
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0 -> 32768
On node 0 totalpages: 32768
Normal zone: 256 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 32512 pages, LIFO batch:7
Movable zone: 0 pages used for memmap
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: root=/dev/mtdblock2 rootfstype=squashfs,yaffs,jffs2 noinitr
d console=ttyS0,115200 init=/etc/preinit
Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=00000800
Readback ErrCtl register=00000800
PID hash table entries: 512 (order: 9, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 125156k/131072k available (1762k kernel code, 5804k reserved, 312k data,
2116k init, 0k highmem)
SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 452.19 BogoMIPS (lpj=2260992)
Mount-cache hash table entries: 512
net_namespace: 484 bytes
NET: Registered protocol family 16
MIPS: machine is MikroTik RouterBOARD 493/AH
NET: Registered protocol family 2
Switched to high resolution mode on CPU 0
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
squashfs: version 3.0 (2006/03/15) Phillip Lougher
Registering mini_fo version $Id$
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
yaffs Oct 28 2008 01:00:34 Installing.
msgmni has been set to 244
io scheduler noop registered
io scheduler deadline registered (default)
Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
console handover: boot [early0] -> real [ttyS0]
ag71xx_mdio: probed
NAND flash driver for RouterBoard 4xx series version 0.1.10
NAND SPI clock 28333 kHz (AHB 170000 kHz / 6)
FLASH SPI clock 28333 kHz (AHB 170000 kHz / 6)
NAND device: Manufacturer ID: 0xad, Chip ID: 0x76 (Hynix NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 3 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x00000000-0x00040000 : "booter"
0x00040000-0x00400000 : "kernel"
0x00400000-0x04000000 : "rootfs"
mtd: partition "rootfs" set to be root filesystem
split_squashfs: error occured while reading from "NAND 64MiB 3,3V 8-bit"
Atheros AR71xx SPI Controller driver version 0.2.2
Atheros AR71xx hardware watchdog driver version 0.1.0
ar71xx-wdt: timeout=15 secs (max=25)
Registered led device: rb4xx:yellow:user
TCP vegas registered
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
Freeing unused kernel memory: 2116k freed
Algorithmics/MIPS FPU Emulator v1.5
PPP generic driver version 2.4.2
ip_tables: (C) 2000-2006 Netfilter Core Team
nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
wlan: trunk
ath_hal: module license 'Proprietary' taints kernel.
ath_hal: 2008-10-02 (AR5210, AR5211, AR5212, AR5416, RF5111, RF5112, RF2413, RF5
413, RF2133, RF2425, REGOPS_FUNC, DFS, XR)
ath_rate_minstrel: Minstrel automatic rate control algorithm 1.2 (trunk)
ath_rate_minstrel: look around rate set to 10%
ath_rate_minstrel: EWMA rolloff level set to 75%
ath_rate_minstrel: max segment size in the mrr set to 6000 us
wlan: mac acl policy registered
ath_pci: trunk
ar71xx-wdt: enabling watchdog timer
root@OpenWrt:/#
