For the last year we have experienced the operational problem on the 5.8 band (v.3.x) … none of 5.8 frequencies works !
If we put Alvarion AP at the same spot everything works well.
Does anybody have suggestion or idea how to overcome this issue ?
What exaclty you do when take mikrotik out and put alvarion? Alvarion is using the same antenna and
cable or are they using integrated panels?
Its important to know that to start debuging the problem. If antennas are the same it can indicate
a card problem. If not check if cables are ok and if antennas are designed to work on 5.8Ghz.
