optimal configuration
Recently I upgraded my old box router with RB4011iGS+. Because I’m new to Mikrotik ecosystem I would like to ask for advice. The router is for home-use with a lot of connections from different devices, most of them are used for Plex (Media Server) and web browsing. Please take a look at my configuration and advice or ask if something is unclear
# dec/02/2018 17:09:00 by RouterOS 6.43.4
# model = RB4011iGS+
add admin-mac=B*******2 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    password=***** use-peer-dns=yes user=*****
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/system logging action
add email-start-tls=yes email-to=******@gmail.com name=email target=\
    email
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add address=192.168.1.1/24 comment=defconf interface=ether2 network=\
    192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
/ip dhcp-server lease
add address=192.168.1.103 client-id=1:a0:1d:48:c7:93:9c mac-address=\
    A0:1D:48:C7:93:9C server=defconf
add address=192.168.1.106 client-id=1:0:c:29:48:33:c7 mac-address=\
    00:0C:29:48:33:C7 server=defconf
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 name=router.lan
/ip firewall address-list
add address=192.168.1.0/24 list=support
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you nee\
    d this subnet before enable it" disabled=yes list=bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you \
    need this subnet before enable it" disabled=yes list=bogons
add address=192.168.0.0/16 comment="Private[RFC 1918] - CLASS C # Check if you\
    \_need this subnet before enable it" disabled=yes list=bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=\
    bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=bogons
add address=224.0.0.0/4 comment=\
    "MC, Class D, IANA # Check if you need this subnet before enable it" \
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=add-src-to-address-list address-list=Syn_Flooder \
    address-list-timeout=30m chain=input comment=\
    "Add Syn Flood IP to the list" connection-limit=30,32 protocol=tcp \
    tcp-flags=syn
add action=drop chain=input comment="Drop to syn flood list" \
    src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner \
    address-list-timeout=1w chain=input comment="Port Scanner Detect" \
    protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment="Drop to port scan list" \
    src-address-list=Port_Scanner
add action=jump chain=input comment="Jump for icmp input flow" jump-target=\
    ICMP protocol=icmp
add action=drop chain=input comment="Block all access to the winbox - except t\
    o support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUP\
    PORT ADDRESS LIST" dst-port=8291 protocol=tcp src-address-list=!support
add action=jump chain=forward comment="Jump for icmp forward flow" \
    jump-target=ICMP protocol=icmp
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
    bogons
add action=add-src-to-address-list address-list=spammers \
    address-list-timeout=3h chain=forward comment=\
    "Add Spammers to the list for 3 hours" connection-limit=30,32 dst-port=\
    25,587 limit=30/1m,0:packet protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 \
    protocol=tcp src-address-list=spammers
add action=accept chain=input comment="Accept DNS - UDP" port=53 protocol=udp
add action=accept chain=input comment="Accept DNS - TCP" port=53 protocol=tcp
add action=accept chain=input comment="Accept to established connections" \
    connection-state=established
add action=accept chain=input comment="Accept to related connections" \
    connection-state=related
add action=accept chain=input comment="Full access to SUPPORT address list" \
    src-address-list=support
add action=drop chain=input comment="Drop anything else! # DO NOT ENABLE THIS \
    RULE BEFORE YOU MAKE SURE ABOUT ALL ACCEPT RULES YOU NEED"
add action=accept chain=ICMP comment="Echo request - Avoiding Ping Flood" \
    icmp-options=8:0 limit=1,5:packet protocol=icmp
add action=accept chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=\
    icmp
add action=accept chain=ICMP comment="Time Exceeded" icmp-options=11:0 \
    protocol=icmp
add action=accept chain=ICMP comment="Destination unreachable" icmp-options=\
    3:0-1 protocol=icmp
add action=accept chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP comment="Drop to the other ICMPs" protocol=icmp
add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP \
    protocol=icmp
add action=fasttrack-connection chain=forward comment="Fasstrack DNS TCP" \
    dst-port=53 protocol=tcp
add action=fasttrack-connection chain=forward comment="Fasttrack DNS UPD" \
    dst-port=53 protocol=udp
add action=dst-nat chain=dstnat comment="Open VPN" dst-port=1194 \
    in-interface=pppoe-out1 protocol=udp to-addresses=192.168.1.106 to-ports=\
    1194
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Bucharest
/system logging
add action=email topics=critical
/system package update
set channel=development
/system routerboard settings
set silent-boot=no
/system scheduler
add interval=3w name="Package upgrade" on-event=\
    "system package update install" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=nov/19/2018 start-time=03:00:00
add interval=3w name="Router board Upgrade" on-event=":global Var1\r\
    \n:global Var2\r\
    \n:set Var1 \"\$[/system package get system version]\"\r\
    \n:set Var2 \"\$[/system routerboard get current-firmware]\"\r\
    \n:if (\$Var1>\$Var2) do={/system routerboard upgrade;\r\
    \n/system reboot;\r\
    \n}" policy=\
    start-date=nov/19/2018 start-time=03:30:00
add interval=3w name="Config Backup" on-event="/export file=export \r\
    \n/tool e-mail send to=\"aurel.antici@gmail.com\" subject=\"\$[/system ide\
    ntity get name] export\" \\ body=\" configuration file \$[/system clock ge\
    t date]\" file=export.rsc" policy=\
    start-date=nov/18/2018 start-time=19:06:00
/tool bandwidth-server
set enabled=no
/tool e-mail
set address=188*****6 from=t*****@yahoo.com password=***** \
    port=587 start-tls=yes user=********@yahoo.com
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
