AES-128 is sufficiently secure for most applications which would increase performance compared to AES-256 - the Mikrotik test results indicate 472.6Mbps compared to 359.5Mbps for 1400byte payloads.
The Diffie-Hellman calculations are always carried out in software but only occur during initial key exchange and subsequent rekeying intervals (set by the profile and proposal lifetime= setting). Less bits is faster, the minimum currently considered to be secure is 2048.
Dear tdw,
thank you for comment on MTU, it seems to bring stability to tunnel. Before changing MSS it was running at speed oscilating from 0,5 to 20 mbps. After change MSS, tunnel is running on 60-70mbps.
It is on 100mbps line running solidly at speed of 95mbps. So it can be better but result is fair enough.
@vanikcz, how did you test the tunnel speed? There are actually two effects of fragmentation.
One is systematic and foreseeable - doubling the rate of “packets” (actually, fragments) to be transported and slightly increasing the bit rate as Ethernet & IP headers for the fragments have to be added. This effect alone should just reduce the throughput smoothly.
The other one can only be seen on some network paths that drop the 2nd fragments, which effectively causes the complete packets to be lost as they cannot be reassembled. And if this happens, throughput testing using Mikrotik /tool bandwidth-test shows variable throughput similar to what you describe, but if you sniff what actually happens, you find out that some TCP sessions stall completely and get replaced by new ones. Whether real TCP sessions, i.e. not those created by bandwidth-test in multi-session mode, succeed depends on whether all fragments are dropped or only part of them, and on how the TCP stacks of the enpoints deal with packet loss and retransmission.
Also worth noting - fragmentation does not increase the amount of IPsec calculations per payload packet, because what gets fragmented are the resulting (transport) packets, not the payload ones.
@sindy
Would we be able to get better performance for the IPsec if we are using CPE for specific user (IRQ).
ATM other users are on auto,but im planning to assign specificate CPE (hEX S), and one unique for crypto.
see the folowing picture
@nichky,
I have no knowledge how it actually works under the hood, so the following is just my assumption based on the fact that arrival of the encrypted packets in wrong order has detrimental effects on the throughput and that there used to be issues related to this in the early days of multi-core implementations: I would expect that the system itself sticks the processing of each particular security association to a single core (to avoid packet overtaking) automatically. So what could be helpful for IPsec performance would be to prevent all other tasks from using the same core rather than to just manually stick all crypto processing to a single one, but this could only be done on dual core systems as you can only manually specify a single core for each irq, not a list. I’ll go even further in my assumptions - since the performance test results published on the product pages always show better results for a single tunnel, I would expect the system to stick the SA for each direction of the single tunnel to a separate core. If so, locking crypto processing to a single core would even have a negative effect on the throuhgput as it would force both SAs to the same core.
